Modding A Sleeper
Old Jan 5, 2009 | 04:31 PM
  #31
cjdm98's Avatar
Default RE: Modding A Sleeper
Forced induction=Turbo/SC
N/A=Naturally aspirated
Old Jan 5, 2009 | 04:35 PM
  #32
AccordLXMaster's Avatar
ok check this out...would putting a nitrous be better than a turbo??....and which would be better with the h22
Old Jan 5, 2009 | 04:44 PM
  #33
finch13's Avatar
FI = forced induction
I have the TL-S rear bar on right now, with the stock front. Balances out the steering with a touch of oversteer.
Go to an Acura dealer and order these parts:
52306-SEP-A11 Rear Bushing (you need 2)
52300-SEP-A11 Rear Stabilizer aka Sway Bar (you need 1)
52308-S3M-A00 Rear bushing Bracket (you need 2)
And if you shear a bolt during the install:
93402-08016-08 BOLT-WASHER (8X16) (you need 4 for a brand new install)
And if you cant get the links off like me and need new ones:
52325-S84-A01 Left Stabilizer Link
52320-S84-A01 Right Stabilizer Link
They might cost you a penny though... I had to pay $110 for mine at the dealer, but theyre listed at $30/ea online for OEM ones.
Old Jan 5, 2009 | 06:22 PM
  #34
falkore24's Avatar
A few things: Brandon, FWD can-t oversteer.
Nitrous is a lot cheaper than turbo or SC ..... do it right though. Bottle heater, blanket, high pressure control for heater, purge, window + WOT activation and a wet system.
If you have nitrous, get a header. It will keep the exhaust temps down since there is more of a buffer zone between the main exhaust stream and the metal pipe, plus the greater expansion of the exhaust will cause a little cooling due to the pressure/ temp relationship of gasses.
Old Jan 5, 2009 | 07:00 PM
  #35
ORIGINAL: finch13
preciate it now i know exactly what to get...this increases what part of performance??
and why do i order these from acura instead of honda??
Old Jan 5, 2009 | 07:24 PM
  #36
cjdm98's Avatar
Those parts are TL parts..and will fit on your car.
Old Jan 5, 2009 | 07:58 PM
  #37
BlkCurrantKord's Avatar
I think before you do any more car mods. You need to do some driver mods.
Old Jan 5, 2009 | 08:08 PM
  #38
ORIGINAL: BlkCurrantKord
thats what the sway bars are right or are u referring to something else???
Old Jan 5, 2009 | 09:28 PM
  #39
I'm referring to you fully understanding what each thing does before you just decide to buy it and throw it on your car.
Old Jan 5, 2009 | 10:04 PM
  #40
well thats what im here for is it not??....when im referred to somethin i usually as what it does or how will it help....for instance the sway bars....what exactly will it do for my car...as far as changing them anywayz
