Need help asap
Old Sep 19, 2011 | 04:36 PM
justanswerquestionplease's Avatar
Default Need help asap
got a buddie with a 1994 or 1995, pretty sure 94, but he has exhaust with a aftermarket set up, guessing its cat back, an got a buddie with a 1992 bone stock, can i swap the systems ? from the cat back. will it be direct bolt up. FYI yes of course there accord
thanks !
Old Sep 19, 2011 | 05:15 PM
g22cd5's Avatar
Supper Moderator
yes and no. I used a 94ex cat back on my 93. Most everything fits right but when you get to the axle back the 94 exhaust is a little bit longer. So you will have to cut both of the flanges off and take a section of pipe out and have it welded back. Test fit the exhaust 1st be4 you start cutting
Old Oct 8, 2011 | 06:22 PM
jesse j's Avatar
what if you took a 93 and tried to put it on a 94? would it be too short? i was also told that it wouldnt fit because when they did the 94 the suspension was different and it got in the way of a 93 catback fitting properly. yes or no? any help is appreciated, need a new exhaust but cant pay retail price.
Old Oct 9, 2011 | 12:43 PM
g22cd5's Avatar
Supper Moderator
donno about the 93 exhaust fitting I have never tried that. I don't see how the 94 suspension is different as they all the 90-97 accords share the same suspension components. I'm currently using a WHOLE rear suspension set/ rear disc break set up up from a 94 on my 93 so I think that info must be false
brandyn
Nov 26, 2013 05:31 PM
firechicken
Feb 2, 2010 03:20 PM
chevync20
Aug 18, 2006 03:42 AM
fryhead
Feb 27, 2006 10:04 PM
pji84
Jan 27, 2006 07:03 AM
