need idea for headers
Old Feb 13, 2011 | 08:43 AM
c.atkinson17's Avatar
Default need idea for headers
i got a 99 2.3 automatic 4cyl ex. i have an ebay intake system, which i am thinking about getting rid of because it makes my car sound like an air boat. but im looking for low end torque mainly. i also have a friend that told me to go with the 4:2:1 headers and then go to get an exhaust to match it. im not looking to spend a **** load, just looking for ideas. thanks
Old Feb 13, 2011 | 03:07 PM
vipjdm-Justin's Avatar
exhaust will free up airflow but won't give you much power...intake is probably your quickest easiest way to get a few horses. but maybe pick up a set of ebay headers..might need to "fit" them a little but alot of people go with those.
Old Feb 13, 2011 | 04:10 PM
g22cd5's Avatar
Supper Moderator
ditch your exhuast idaa and spend your money on a cam you will see much more power gain for your money
Old Feb 14, 2011 | 09:15 AM
ok, so i dont know too much, but all i do know is that my car is a single overhead cam, so did u mean to get an upgraded cam? or something? is it a mod, or is it just tuning it up or cleaning it up to make it run better?
Old Feb 16, 2011 | 12:39 PM
g22cd5's Avatar
Supper Moderator
you can get a CAm re-grind. It will yield more power than your exhaust will. A cam shaft is what pushes the valves open and closed in the engine head. You can get diff. types of re-grinds. With more lift the cam your allowing more air and fuel in each cyl and allowing it to escape faster 2. Depending on what re-grind you go with you might need to upgrade your valve train and get your ECU tuned for the cam upgrade. To get the full potential out of your upgrade.
Old Feb 17, 2011 | 08:56 AM
thanks for the info, that sounds like a lot of money. im gonna have to save up for that, plus my car keeps messing up on me so i need to fix that stuff first.
Old Feb 17, 2011 | 03:13 PM
also im a newb when it comes to this stuff, so would i have to purchase a cam regrind or would i send my cam to get regrinded? if that makes any since... also is it easy to do.... and then how would i go about tuning the engine to it?
Old Feb 17, 2011 | 04:44 PM
Everyone started out as a newbie, don't feel bad.
Place that grinds the cam for you, they will have to tell you whether they have one for exchange, or whether you need to send yours in & wait for it.
Then you'll want to give the car to a tuning shop so they can re-program your fuel & spark maps.
But you're absolutely right, you gotta deal with broken stuff first, & save up for the fun stuff.
Old Feb 17, 2011 | 05:15 PM
about how much would that cost? it turns out that all the problems i had were just loose bolts from when me and a buddy replaced the engine and just rushed through it and didnt tighten things down enough. that and my cat is bad which ill fix when i buy my new exhaust soon
Old Feb 17, 2011 | 08:01 PM
g22cd5's Avatar
Supper Moderator
you can buy a cam CORE...so you won't be out of a car while you wint for the re-grind
F_bomb
Jul 4, 2007 08:20 AM
thunder_x
Sep 27, 2006 11:00 PM
poff1986
Aug 2, 2006 03:43 PM
joshuaaaronalpert
Dec 30, 2005 03:40 PM
LiLLita361
May 4, 2005 02:16 AM
