new aem sri, need install help
Old May 31, 2007 | 10:14 PM
noboundaries6289's Avatar
Default new aem sri, need install help
hey all, i bought an aem sri off cardomain and im wondering if anyone can provide any instructions on how this goes in. thanx ahead of time
Old May 31, 2007 | 11:03 PM
pyaarawala's Avatar
Default RE: new aem sri, need install help
It's very easy. Although I'm not sure what the 95 Honda Accord looks like under the hood, for my 98 Accord it's simply removing the factory intake from the throttle body (one clamp holds it on), and removing the rest of the intake. The intake should some kind of thick black piping that may feel like some kind of rubber. Also remove the vaccum hose from the intake, you'll see it (also connected by a small clamp).
After removing the factory intake you simply put on the connector that came with the sri to one end of the new intake, and squeeze that onto the throttle body. Make sure you do it to the right side. The side with the vaccum hose opening on your new sri should be closest to the throttle body. Just clamp everything on and it'll be set. This is how it was for my 6th gen accord, it should be very similar.
Whatever differences between the 95 and 98 accord I'm sure other users on this forum will point out after me.
Old Jun 1, 2007 | 02:34 PM
03Sleeper's Avatar
There's online directions at the AEM site (PDF Document).
There should be instructions with the package itself.
But the installation is easy...disconnect some tubes, reroute coolant lines (optional), lift the stock airbox out, put in the new intake. 20 minutes.
Oh, and use WD-40 or liquid wrench to loosen your bolts.
eiji
12
Aug 13, 2011 10:08 PM
jasonfridlund
Jun 24, 2009 02:37 PM
Honda_Dude
Feb 21, 2007 08:54 PM
kevin_nguyen0862
Feb 20, 2007 11:16 PM
J dizzle
Nov 1, 2005 10:55 AM
