O2 Sensor Trouble
Old Aug 30, 2009 | 07:25 PM
rwyatt80's Avatar
Default O2 Sensor Trouble
I have a megan racing header and silverline exhaust. I had a leak in my exhaust that was recently repaired (sensor in bank 2 was replaced at this time). It burned out my O2 sensor (bank 1). I replaced the sensor, cleared the code, and the next day the check engine light came back on. The code was for the sensor in bank 1. I am not sure what else to do at this point. I have cleared the code (again) to see if it will return. I have been fighting this exhaust issue for months now...
Old Aug 31, 2009 | 10:34 AM
In 1996, even the V-6 has no bank-2 sensors.
Primary sensor is before the cat, secondary sensor is in the cat. No dual exhaust. No bank-2.
What code? First time & now? OBD-2 has about 4 different codes for each sensor. Even if you do the OBD-1 method (flashing CEL) you still have the sensor vs. preheater for each sensor so there's at least 4 different codes.
Old Sep 1, 2009 | 01:49 AM
rwyatt80's Avatar
The code is p0420 and i have a 1996 accord 4 cyl lx. I have replaced the sensor twice only to have the same problem. Could it be the converter itself and not the sensors??
Old Sep 1, 2009 | 07:50 AM
Yes it could. P0420 is actually a code for the cat, not for the sensors. Thing is, the sensors are the only way the ECU "knows" about a bad cat, so most people hope that it's a sensor problem.
Since you're not getting any high, low, or sluggish errors for the sensors, that also suggests the sensors are OK.
Old Sep 1, 2009 | 03:32 PM
rwyatt80's Avatar
I figured the converter was the culprit. Is there any store online that can be recommended for a good performance converter at a decent price?
Old Sep 2, 2009 | 03:28 AM
rwyatt80's Avatar
Found a new cat. Will let you know what happens...
Old Sep 7, 2009 | 06:49 PM
rwyatt80's Avatar
I have another question before my cat install on wednesday. Will I have to replace my sensors (again!!) I just want to know if I should be looking out for anything else when it comes to my exhaust after the cat has been replaced....
Old Sep 8, 2009 | 10:36 AM
Your sensor should be usable on the new cat. That is, if the mechanic doesn't break it while removing...
Old Sep 9, 2009 | 03:05 PM
rwyatt80's Avatar
I got the new converter put on today...so far so good . I will give it some time (a week or so) and follow up on the progress!!!
Thanks so much!!!
Old Sep 28, 2009 | 09:36 PM
rwyatt80's Avatar
So far so good with my new converter...now my focus is on my cylinder head...it just doesnt end...lol. Thanks again!!
pondrun
Nov 8, 2021 09:40 AM
schreinman
Jul 5, 2015 10:36 PM
rwyatt80
Aug 30, 2009 08:34 PM
dmost30
Sep 8, 2008 12:42 AM
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
