TSX intake on my `07 K24A8
Old Jun 24, 2022 | 09:06 PM
AwGeez's Avatar
Default TSX intake on my `07 K24A8
Finally done thanks to the archived how-to on other forums. The engine in my 7th gen. is basically stock(...with the exception of an AEM dryflow panel filter and a silicone intake boot.). I purchased a used lower intake manifold from a `07 Acura TSX along with the bottom support bracket and thermal gaskets. It's a direct replacement of the stock unit complete with all required vacuum fittings and accepts the stock throttle body.(The larger TSX throttle body can also be used but it requires changing some intake plumbing) The TSX lower intake has a larger, high-volume plenum with bigger intake runners which seems to enhance throttle response and provide a bit more power in the low/mid range. It also provides an audible "growl" as the rpms climb. No CEL or running issues. Technically, it is an OE part which makes the retrofit a bit easier to swallow. Well worth the 45min install and $140 spent, IMO.
danvelazquez
North East
Jun 19, 2015 11:47 AM
Ron V
Jan 4, 2012 06:47 PM
pbplayer257
Jul 12, 2010 01:02 AM
pbplayer257
May 2, 2010 07:58 PM
pbplayer257
Apr 23, 2010 07:40 PM
