v-tech
Old Apr 10, 2006 | 01:25 AM
X___nothingspecial's Avatar
Default v-tech
im sorry, im new to the honda and the v-tech... i was curious what exactly the v-tech is and does
explained in english lol i tried to look it up and i found an explination of it... but it sounded nothing like i was reading in some of the earlier forums
i was just curious if you could help a rookie out please
Old Apr 10, 2006 | 05:18 AM
lightshow's Avatar
Default RE: v-tech
vtech ......variable valve timing and electronic lift control......
two step process occuring at the exact same time.
there is a certain rpm in your motor where volumetric efficiency becomes optimal. at this very time, usually around 4500-5000 rpm. two things happen.
one ....timing is effectively advanced creating more horsepower.
two...... valve lift is increased/higher than it was before. higher valve lift increases horsepower and allows the motor to attain higher rpms without starving.
low lift is utilized at low rpms because it creates more torque.
Old Apr 10, 2006 | 09:51 PM
Default RE: v-tech
okay thanks alot lightshow
Old Apr 23, 2006 | 05:40 AM
legionofone's Avatar
Default RE: v-tech
nice discription light show... if u want that in a nutshell its gives a radical cam when u hammer on it and a normal cam when u are at low rpm...
cypresshills
Dec 3, 2008 09:00 PM
apg96
Dec 9, 2007 03:06 PM
caramel cool
Feb 5, 2006 09:20 AM
jsyjordan
Jan 11, 2006 03:38 PM
Oct 3, 2005 10:34 PM
