what if?????
Old Apr 12, 2008 | 11:41 PM
HORSEPOWERJUNKIE2007's Avatar
Default what if?????
what if you had a catback with an OEM muffler?!is that possible?!because this guy at work claimed he did it!and he hasn't brought his car to work yet,but is it possible?!won't the sound be horrible?
Old Apr 12, 2008 | 11:51 PM
19Accord97
Default RE: what if?????
It would be possible, but pointless. The input diameter for the muffler is going to be the same as the oem exhaust piping, which ultimately makes the larger pipe before the muffler useless. It would essentially be the same performance as a stock exhaust, and louder if you remove the resonater.
Old Apr 12, 2008 | 11:53 PM
gomarlins3's Avatar
^I agree, what's the point?
Old Apr 13, 2008 | 10:50 AM
falkore24's Avatar
^^^ ..... not true that there's no gain. I agree with modifying the inlet to get the larger diameter, but the OEM mid-pipe is the largest restriction in the stock setup. Also, the OEM pipe has a smaller pipe in the core that restricts even more. For a quiet performance upgrade, I recommend that the mid-pipe is upgraded and a 24-27" resonator is used along with a dynomax super-turbo muffler (OEM type with internal guide vanes) with the inlet sized to match the upgraded piping.
