5th Gen Wagon - Southeastern Vermont/ River Valley
Old Nov 20, 2016 | 08:55 AM
Sylvan-SE-VT's Avatar
Default 5th Gen Wagon - Southeastern Vermont/ River Valley
Hi friends!
Brand new to the forum, fairly new to my Accord, Lover of Hondas.
Bought my '97 Wagon this summer. Project/daily driver. Ok condition. Just your average 20 yo wagon. 260,XXX mi.
So far-
-Replaced air box/ air cleaner box (missing)
-New plugs, wires, valve cover gaskets, sway bar links
-bypassed the super noisy air compressor until I get a chance to diagnose and repair it
Needs-
-there's an oil leak in or around the distributor
-rear trailing arms/control arms bushings are shot
-the upper coolant hose recently started leaking. someone glued the thing back on there instead of putting the hose back on right.
-Doing the brake service soon
-The front brackets that hold the bumper on have all but fallen off and need to be re-welded
-Some minor rust patches and one hole need to be patched on the body. problem areas are rear wheel well, right -after the rear door.
-Alignment, hopefully. the thing pulls just so gently to the left
Looking for any buds in the area.
Thanks for reading
Old Nov 20, 2016 | 10:18 AM
Welcome to HAF.
Sorry, too cold up there so I'm way south of you
Easy try on the oil leak near the dist, the o-ring that goes around the dist shaft where it goes into the head gets old and hard over time and will leak. Fairly simple job, remove the cap - leave the wires on it - and note where thee dist rotor is pointing. Remove dist, replace the rock hard o-ring and re-install everything - make sure the dist rotor is in the same position......while you have it off, check that heater hose right under the dist - if oil has been dripping on it it can get soft/oil soaked.
Good luck and enjoy the ride
Old Nov 21, 2016 | 04:11 PM
Prospector's Avatar
Hello, Sylvan
Welcome to the forum.
One wish I have of Honda is that they bring back the wagon on an Accord chassis, enjoy yours
RGen7
Jul 15, 2014 05:17 PM
tnguyen600
North East
May 23, 2008 12:20 AM
Sofa_King
Sep 4, 2007 08:35 PM
II
Mar 13, 2007 08:22 AM
