89 accord lxi
Old Mar 10, 2015 | 08:23 AM
dl89's Avatar
Default 89 accord lxi
My car has a skip that has gotten worse over the past few weeks,check engine light is not on ,any ideas ? I think its a sensor and not ignition Issue ,stick your foot in the gas it will clear up a little,but it sounds like its popping back thru the throttle body ?
Old Mar 10, 2015 | 06:15 PM
Welcome to HAF.
I'm a big fan of the old 3rd gen's
Check for codes just to be sure - view the led on the ecu from behind the dirvers seat, open the "window" and turn the key to on.
Tune up items up to date - cap, rotor, plugs, test wires, air filter?
Check the timing - both mechanical and ignition...set #1 to TDC (view the flywheel mark) and then see how the cam ger marks are. Then remove the proper vac lines from the dist and get a timing light to the flywheel marks.
PS - for my own interest - how many doors on your LXi - 2, 3 or 4?
Old Mar 10, 2015 | 08:19 PM
dl89's Avatar
Welcome to HAF.
Its a 2 door ,thank for the advice,at least gives me a direction to start in
Old Mar 10, 2015 | 08:57 PM
Suggest also checking cylinder compressions. A leaking valve can cause backfiring into intake. Low compression on one cylinder would suggest possible leaking valve. Further checks necessary to confirm valve leakage.
raydavid93
Mar 16, 2013 09:23 AM
wknox
Jan 24, 2011 09:09 AM
daemonhat
Mar 26, 2006 09:58 AM
Sellmanb
Dec 27, 2005 03:02 PM
86accordlxi
Nov 13, 2005 04:09 AM
