90,000 mile tune up?
Old Jan 19, 2007 | 07:00 PM
cardumbie87
Default 90,000 mile tune up?
Hey everyone. hope you guys are having a fantastic friday! I have a question, I have a 2001 Honda Accord, EX 4 cyl model. I just recently surpassed the 90K mile marker. Is there a 90K mile tune up I need to take it in for? Thanks
Old Jan 19, 2007 | 07:13 PM
sir_nasty's Avatar
Default RE: 90,000 mile tune up?
IF you haven't done the timing belt yet I would get that done along with the seals, tensioners and water pump. Tranny drain/re-fill, inspect the belts and check for leaks, air filter (if it's due), fuel filter... but the biggest thing is the timing belt
Old Jan 19, 2007 | 07:17 PM
cardumbie87
I bought the car in June of 05' with 73K miles on it. I'm not sure if the timing belt has ever been replaced. I'm new to learning about cars: what is the seals, tensioners, & water pump. I had the tranny drained & refilled during an oil change in Dec, air filter was also replaced at that time. How much does all that cost?
Old Jan 19, 2007 | 07:22 PM
sir_nasty's Avatar
The water pump requires the removal of timing belt etc. so it's best/easiest to replace that when doing the job.... Here's some great photos of a 94 (it's similar) so you can see what each part is.... I believe that if you had a mechanic do all the work you're looking at anywhere from $400-$600 for all the parts/labor
Old Jan 20, 2007 | 01:00 AM
Hi Member CarDummie..welcome to the forums..
Here is a great rule to follow all of your life...If and when you purchase a new USED car...treat it as if nothing has been done to it at all and then do most everything..this is the only true way you will know if something has been done..eNuff Said
Old Jan 20, 2007 | 01:06 AM
cardumbie87
Thanks WheelBrokerAng. I wish I could do something about it, but at this point I dont really have $400 or so laying around to get that checked out. I would def do that if i could but I'm a student in college...trying to survive. I'm concerned the timing belt might go out soon, but praying for the best.
rsolorio
Nov 1, 2008 01:02 PM
winndogg34
Jul 18, 2008 11:31 AM
Mikes Machine
Nov 14, 2007 02:20 PM
accord4sroy
Jun 30, 2007 04:52 PM
Mar 6, 2007 08:27 PM
