95 Accord 2.2l Vtec Idle Surge PLEASE HELP
Old Jun 27, 2024 | 03:29 PM
BigWill95Accord's Avatar
Default 95 Accord 2.2l Vtec Idle Surge PLEASE HELP
I have a 1995 Honda Accord 2.2l Vtec 5speed with idle surge. I have installed new IAC, FITV (turned in all the way), TPS (and calibrated), cleaned the pcv and egr system , new Thermostat, Radiator (bled coolant), temperature switch, did a smoke test and the only place the smoke came out was at the bottom of the air filter box. I have intake gasket but have not changed them yet, but I figure if they were bad I would of seen smoke coming out but there was none. Can someone PLEASE give me an idea on this!!
P.S. When i bleed the coolant, should it be a steady steam of coolant coming out of the bleeder? Cause it spits coolant for 2 seconds, stops for 4-5 seconds, spits for 2 seconds, stops for 4-5 seconds, etc, etc, etc... And that is with the RPMS at about 1500, heater turned to hot (dash fan not turned on), and the radiator fan running.
Old Jun 27, 2024 | 09:44 PM
2016firstcar's Avatar
Have you checked for any engine codes? Might give you a clue.
Old Jun 28, 2024 | 03:26 AM
I haven't checked for any codes and the check engine light is not on. I'll stop by advance auto and have them check.
Old Jul 1, 2024 | 02:59 PM
Stopped by Advance Auto, and no codes. I'm trying to bleed the coolant again... ugh!
Bmedrano98
Dec 12, 2019 05:48 PM
Yochanan
May 20, 2019 05:42 PM
lefty310
Oct 19, 2013 01:23 PM
littledrakon
Jun 13, 2012 12:51 AM
compguru89
Dec 24, 2007 07:03 PM
