Help
Old Jun 17, 2020 | 05:04 PM
Stevebrewer99's Avatar
Default Help
The peg timing belt tensioner pivots on it is sheared off does the old CV one off to put new dowel in so I can put tensioner on it to pivot,please help me..stevesbrew3@gmail.com ty
Old Jun 18, 2020 | 12:43 PM
The Toecutter's Avatar
I think I'd replace the stud, since it's worn. I think the "peg" you're mentioning is for the spring to hold the "automatic" tension of the tension bearings for the timing belts. You should be able to manually set them though, once you replace that worn stud. I think that broke off stud, is just a rod in the oil pump cover (not 100% sure though.
Old Jun 18, 2020 | 01:46 PM
So on the right side of back of tensioner is a place for it to slide on and the spring is on the left side of it
Old Jun 20, 2020 | 05:29 PM
Yes, I believe so. It's hard to tell for certain looking at your pics.
75Gremlin
May 23, 2020 05:06 PM
carid
Nov 15, 2019 05:12 AM
ßlåçk§mókè
Jan 8, 2011 12:05 PM
Tippman7641
Sep 5, 2008 09:40 AM
blacknight07644
Sep 14, 2007 12:25 PM
