Lopeing after egr valve change?
Old May 24, 2020 | 09:33 PM
Jeff88's Avatar
Default Lopeing after egr valve change?
My first post! so sorry if my etiquette isn't on pointSo, vehicle in question is 98 honda accord 4 cyl LX. It was running just okay with the egr engine code. I swapped out the EGR and also cleaned out the throttle body, intake manifold and upper plenum. All new gaskets. Also had to remove the fuel rail and of course all fuel injectors. I attempted to clean the fuel injectors while they where off. When I first fired it up it wasn't getting unough fuel and I realised I had left off the tube which connects the idle air control valve to the fuel rail (dont know if it matters) I then re-connected it fired up but now its idling terribly! If I open the throttle it seems to respond okay but idles down really fast.
My guess is either I damaged a fuel injector or an one of the many electrical connections?
Anyone had a similar problem or have any ideas? Thanks for any advice! - Jeff
Old May 24, 2020 | 09:52 PM
Seanjordan20's Avatar
Do you have a check engine light if so what are the codes
Old May 26, 2020 | 01:16 PM
The Toecutter's Avatar
On my wife's 2000 Accord, after I replaced the EGR, and had the upper part of the plenum off, I had to replace the IAC valve in order to get rid of the loping. I don't know if you're having the same issue or not though.
JacobDibble
Mar 29, 2020 06:26 PM
svwvk
Jun 18, 2013 12:21 AM
simplified
Feb 19, 2008 11:14 AM
sir_nasty
Feb 7, 2007 04:19 PM
dinzer
Aug 9, 2005 11:17 AM
