Need Help
Old Jun 27, 2019 | 02:51 PM
Slammed92Acoord's Avatar
Post Need Help
Went to store, cut car off. Came out and wouldnt start. Wont even turn over. I dont think i hear the fuel pump either. Havent checked to see if its got spark at plugs yet, was thinking maybe a ground wire came loose or maybe relay??? Car doesnt do anything. any ideas??
Old Jun 27, 2019 | 03:10 PM
shipo's Avatar
I don't understand, if the engine won't turn over, why are you worried about spark or the fuel pump? Unless I'm missing something, you have a bigger issue, like a dead battery, corroded battery cables, or maybe a dead fusible link (if such exists on your car).
Old Jun 27, 2019 | 05:46 PM
would a dead battery cause fuel pump not to wokr?
Old Jun 27, 2019 | 07:58 PM
shipo's Avatar
What do you think powers the fuel pump?
Old Jun 27, 2019 | 08:59 PM
thanks guy, just wasnt sure how it worked if it was running fine since the 12th of this month. (when i put new motor in car). Battery is still under warranty. Didnt understand what could kill the battery. But maybe alternator bad. Im going to cross starter to see if it cranks. if so then yea maybe battery. Checked with test light all main power source is getting power. But i believe if starter doesnt crank it, could it possibly be the clutch sensor thing on side of pedal???
Old Jun 29, 2019 | 02:54 PM
Does anyone know if i cross those wires on clutch safety switch, will it continue to run power and possibly burn up? Car cranks up by crossing the starter out, so i put a staple in plug (clutch sensor) to see if sensor was bad and it is, car cranked right up once i crossed wires. ???
Old Jun 30, 2019 | 02:37 PM
The Toecutter's Avatar
Sounds like you have either a bad clutch switch, or 1 that is mis-adjusted.
99accordf23a5
May 6, 2014 12:51 AM
brandyn
Nov 26, 2013 05:31 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
ryan ortego
May 19, 2005 06:06 PM
