2002 Honda accord 2.3 vtec
Old Jun 17, 2019 | 07:10 PM
Charlesvan's Avatar
Default 2002 Honda accord 2.3 vtec
My problem on my 2.3 vtec have about 90 psi on just one cylinder n the other 3 doent have any compression at all it does have a new timing belt pulleys water pump the car will crank up n run but u can tell it has a misfire do I just need to replace or rebuild the eng I dont know much about the car I bought it cheap n was told it needed a timing belt I bought the belt n everthing but when was ready to replace it it had a new one on it wasnt broking but notice the scear key was broking replace it n this where I'm now. Thanks for any help
Old Jun 17, 2019 | 09:11 PM
shipo's Avatar
Hard to know for sure, but it sounds like the timing belt broke while the engine was running and damaged the valves. Assuming this is the case, your two best options are to yank the head and have it reconditioned and new valves put in, or buy a used engine and have it put in.
Regarding the head, the best way to know if the valves have suffered damage, have a leak down test performed on the engine and have the cylinders bore-scoped.
Old Jun 19, 2019 | 09:31 AM
Charlesvan's Avatar
Thank you
Old Jun 20, 2019 | 06:37 PM
hondaslave1342's Avatar
If you had only compression in one cylinder it would not run..
Old Jun 23, 2019 | 07:44 PM
Charlesvan's Avatar
I'll check again I get a different compressor tester
Old Jun 24, 2019 | 03:43 PM
The Toecutter's Avatar
Recheck the compression, and even go as far as doing a leak down test. This will tell you if the cylinders are sealing (at the head).
If it had been running when the timing belt broke, I for see an engine change in your future, and a head replacement at minimum (due to bent valves). Once you pull the head, you'll know what kind of carnage was done (it might have damaged some pistons too). These engines are interference engines, which means timing IS critical.
Old Jun 24, 2019 | 05:40 PM
shipo's Avatar
The only possible good news here is, while valve damage is all but guaranteed when the timing belt breaks, piston damage is exceedingly rare.
Old Jun 25, 2019 | 01:28 PM
Good to know. I've always wondered about that,even though I replaced the timing belts in both of our 6th gen Hondas. So damage for the most part would be limited to the head then (valves and guides).
Old Jun 25, 2019 | 01:39 PM
shipo's Avatar
Yup.
Over the years I think I'm only seen or heard of one instance where the pistons sustained damage, and so far at least, I've never heard of this happening to a Honda motor.
Old Jun 30, 2019 | 02:38 PM
Yup.
Very good to know. I've always worried about.
mhbailey12
Oct 12, 2014 12:18 AM
cd51994accord
Jan 30, 2014 12:56 PM
ianhillsman
Oct 10, 2009 01:30 PM
Howellbl
Mar 11, 2009 06:07 AM
