Need some help with BRAKE Replacement
Old Mar 28, 2009 | 06:28 PM
lukkydeep
Default Need some help with BRAKE Replacement
Hello,
I went to HONDA Showroom and got the below work done....They charged me $580 - Did they rip me off?
30,000 Mile Service (also @ 60K, 90K, 120K)
- Change engine oil(up to 5 quarts)
- Replace engine oil filter
- Replace drain bolt washer and torque
- Inspect all fluid conditions and levels(top off if necessary)
- Rotate tires, and adjust tire pressure
- Inspect front and rear brakes
- Inspect pads and discs for wear
- Inspect calipers for damage, leaks, and tightness
- Clean and lube slide rails in calipers
- Inspect wheel cylinders for leaks(if applicable)
- Inspect brake linings for cracking, glazing, wear, or contamination
- Inspect parking brake and adjust if necessary
- Inspect brake hoses and lines(including ABS), check master cylinder, proportioning valve and ABS modulator for damage or leaks
- brake fluid renewal
- Inspect tie rod ends, steering rack & boots
- Inspect steering linkage and rack
- Inspect steering boots for damage or leaking grease
- Inspect steering fluid lines for leaks or damage
- Inspect suspension components
- Inspect suspension bolts for tightness
- Inspect condition of ball joints and boots
- Inspect driveshaft boots for cracks and check bands for tightness or leaks
- Replace engine air cleaner element
- Replace dust and pollen filter
- Inspect and adjust drive belts
- Lubricate all hinges, locks, and latches
- Inspect cooling system hoses and connections
- Inspect cooling system for damage, leaks, or deterioration
- Inspect cooling system for proper fan operation
- Replace transmission fluid
- Inspect battery and charging system
- Inspect exhaust system. Check catalytic converter heat shield, exhaust pipe, and muffler for damage or deterioration
- Inspect fuel lines and connections
- Inspect all lights and position of headlights
- Inspect the vehicle underbody for damage or deterioration
- Perform multipoint inspection
- Road test vehicle
$405
And BRAKE Replacement - $175 - Just BRAKEPADS or rotor resurface!!!
Please let me know your thoughts!!! Thank your for your help in advance.
Old Mar 28, 2009 | 06:41 PM
finch13's Avatar
Huge rip off... they probably spent $60-70 in parts and the rest was labor... and all those inspections probably took under an hour to do.
Old Mar 28, 2009 | 07:31 PM
cjdm98's Avatar
Ripped off indeed.They dont call it a stealership for nothing. All of that you could of done at your own house,for about $100.For parts.
Old Mar 29, 2009 | 09:13 AM
Red face A Suggestion For You!
Go back to the dealer and ask for 1/2 of your money back...call the BBB and ask them how many complaints this dealership has against them..
Attached Thumbnails Need some help with BRAKE Replacement-time_piece_02bysymbolic.jpg
Old Mar 31, 2009 | 05:23 AM
lukkydeep
Thank you for your advice!
How should I approach them? Pls guide or provide any links?
Thanks a ton! In advance
MessAround
Jun 12, 2013 08:47 AM
sach4u1
Oct 10, 2010 03:12 PM
CrmWestwood
Mar 27, 2010 02:21 PM
BigRigg
Jan 25, 2009 05:29 PM
kinneyrhs
Apr 21, 2008 07:27 PM
