Do I absolutely need to replace all brake hardware when doing a brake job?
Old Jun 8, 2013 | 11:06 PM
MessAround's Avatar
Almost A Senior Member
Default Do I absolutely need to replace all brake hardware when doing a brake job?
So if I'm replacing pads and rotors can I clean up and re-use the brake hardware or do I absolutely need to get new hardware?
The hardware I'm referring to specifically is those "retaining clips", two per caliper that fit where the brake pads lock into the caliper (top and bottom) where they slide.
45237-SDA-A01
Those things are expensive, 5.87 each and I would need four. I would just rather re-use them if I could.
What would you guys do?
Old Jun 9, 2013 | 12:42 AM
Hi Member...
As inexpensive as those parts are I say YES!
If your going to do any job right..Do It Right .
Old Jun 9, 2013 | 07:07 AM
If you get OEM pads, the parts are usually included. Not sure exactly what part you mean.
If you mean the little V-shaped springs, these are what I call "relaxation springs". They unload the pad from the brake rotor to reduce sliding drag when no brake pressure is applied. Probabaly worth a few miles per tank, but a good part IMO. They could be re-used, but might get weaker w/ age due to heating/cooling cycles.
Old Jun 12, 2013 | 07:26 AM
I've cleaned & reused those, but look at em to see whether they are OK.
Old Jun 12, 2013 | 08:47 AM
Dr. Drivability's Avatar
most premium brake pad sets come with them, the brake job i just did had them included and they were the wrong retainers (some call them anti-rattle clips) clean'm up with a wire brush and put just a tiny dab of brake caliper lube where the pad ends contact and you'll be golden.
surfkovo
Jun 4, 2014 02:25 PM
nameslot
Jan 15, 2010 02:43 PM
98jeepzj
Feb 11, 2009 06:57 AM
thunder_x
Apr 16, 2007 04:34 PM
