Swapping from f22b2 to a b1 head sohc to vtech
Old May 19, 2020 | 05:45 PM
Jamesaccord92's Avatar
Default Swapping from f22b2 to a b1 head sohc to vtech
Changing heads from f22b2 to f22b1 leaking oil into my spark plugs changed valve cover and gasket 3 times and still leaking into the plugs was told it's probly pistons or something els so I've done some reading and need help to figure out changing from b2 to b1 sohc to vtech on a f22b2 block can anyone please help me and let me know excactly what I need to do to compleat this asap please and thank you for all the info and help
Old May 20, 2020 | 01:25 PM
The Toecutter's Avatar
Well, right off hand you'll need to find a VTEC equipped ECU. Then you'll have to add the wiring needed to run the VTEC. You're probably looking at using a different distributor and coil set up too. I think those are the main things. You might want to get a FSM (Factory Service Manual), so you can study the pin outs, to make sure everything else is correct, and where you need to join into the ECU to run the VTEC valve.
I hope this helps.
johnklosterman79@yahoo.com
Jan 2, 2016 05:49 AM
Bluv
Sep 17, 2012 02:12 PM
tonymazarati
Mar 30, 2012 06:28 AM
Fez
Apr 9, 2007 11:32 AM
