custom turbo kit
Old Apr 20, 2007 | 10:29 PM
hypnoticxhyphy's Avatar
Default custom turbo kit
hey im in the process of building my own turbo kit... (buying all the parts seperately)..
i was thinking about a t3/t4 turbonetics turbo.. (yea i saw the kit.. jst way to expensive for me..)
im running a 2000 coupe auto I4
can anyone help me come up with a parts list and suggestions on a "safe" amount of boost (8psi according to turbonetics)
i could run on stock engine and tranny.. tranny hasnt had problems so far.. but i know this model has been known to have tranny problems..
i eventually want to do some engine upgrades (internals) and maybe a new tranny to hold more power (6spd swap.. a lot of work.. i know..)
i hope to reach 250hp(stock engine/tranny).. and maybe 300-350 after upgrades on them..
any help would be great. thanks
Old Apr 26, 2007 | 04:02 PM
95bentleyLX's Avatar
Default RE: custom turbo kit
i just put my setup on last week with advice gained from this site and so far everythings straight. i peiced everything together on ebay. paid under 700 for everything. no fuel management yet, but i only run 3.6psi. got the custom wastegate spring on ebay (.25bar). told by super members that its "safe" despite check engine light. car runs ok, pulls pretty strong and blows off hard. i should have the dough forinjectors, chrome and dyno tuning by middle of may so ill let u know what it makes. doubt it will make 250, tho
Old Apr 26, 2007 | 04:06 PM
sir_nasty's Avatar
On the 2000 8psi should be safe, I would suggest getting a tranny cooler though since it's an automatic... basic estimates on a 94 accord (140 HP) running 8 psi would bump that motor up to around 225 HP so depending on what you're starting with I don't think 250 is out of the question...
Old Apr 27, 2007 | 11:32 AM
marbro's Avatar
did you get the map bypass? if you didnt thats most likely why youre getting the cel light
Old Apr 29, 2007 | 03:54 PM
hey bently, could you possibly post or PM me a list of parts that you purchased? I need some idea of what to get... thanks
Old Apr 29, 2007 | 09:57 PM
intercooler came from an ebay co. called just-intercoolers http://stores.ebay.com/Just-Intercoolers
$117 shipped
for piping i used my exsisting cai pipe,and acai from my 88 civic(for elbows)
$free
downpipe from ebay http://stores.ebay.com/kami-speedo, for civic, modified slightly to fit under oil pan
$130 shipped
ht18s-2s (2nd gen. RX7 turbo) w/ t3 adaptor plate and oil lineswith tubular manifold from some dude i know locally that had a booosted accord (turbo/mani combos can be found on ebay for $350 or less)
http://myworld.ebay.com/ebaymotors/darknight-imports/
$250 (picked up mine)
tubo xsrfl blow off valve usedfrom my buddys wrx....................easily found for cheap, though: http://stores.ebay.com/JNE-POWER
$50/ approx $120 new
gaskets and **** http://stores.ebay.com/Wyntonm
maybe $50
used wastegate--mine was 75 or so. looks like this is a decent deal: http://myworld.ebay.com/ebaymotors/beers8175/
$75 shipped
finally, i have no fuel enrichment, so i run a modest3.63 psi using a custom wastegate spring(0.25bar)
http://stores.ebay.com/Import-Blowout-Sales
$40 shipped
save up the dough and just do it, man. i was out all weekend spanking the life out of b-swapped hatchbacks, in my 4 door big *** "bentley" for 1/4 of the cost, and at a mere 3.5psi..........wait till i get chrome!!!!!!
Old Apr 29, 2007 | 11:15 PM
haha awesome dude thanks for the info and the links... chrome will definately add hp! dont forget the stickers and underglow!! haha jkjk.. but cheah i was hoping to spend 1500 for 8psi and probably another 500-800 for an extra 10 psi (on the engine)
Old Apr 30, 2007 | 02:57 PM
dude, by chrome i mean thewell known fuel enrichment program that can be tuned @ my local speeed shop so that i can run more psi safely. not chrome rims. check it out http://www.xenocron.com/
Old Apr 30, 2007 | 10:00 PM
hahah oops my bad.. i knew that
Old May 2, 2007 | 04:27 PM
marbro's Avatar
once again seeing as it was ignored, your probably throwing the CEL cause you dont have the map bypass, and you will have to get a new map if youre going to do any chipping cause the stock one isnt ment for a turboed car
