F22B1 SOHC VTEC TURBO?!
Old Aug 22, 2011 | 02:06 PM
  #81
twoj1's Avatar
Originally Posted by g22cd5
lol you know the f22 and h23 share the same crank and rods. They are identical. So if one is cast then the other is also or vice versa...Iv never heard that the f22/h23 crank is cast...might have to look into that one.
Shoot me a PM let me know whats goin on.
You know looking into it you are right about the crank however not the rods..
Engine Rod Length Rod Width Main Bore Pin Bore
F20A 145.0mm/5.709 23.75mm/0.935 ??? 21.97-21.98mm/.8649-.8654
F20B 145.0mm/5.709 23.75mm/0.935 48.00mm/1.890 21.97-21.98mm/.8649.8654
F22A 141.5mm/5.572 23.75mm/0.935 51.00mm/2.008 21.97-21.98mm/.8649-.8654
F22B 141.5mm/5.572 23.75mm/0.935 51.00mm/2.008 21.97-21.98mm/.8649-.8654
F22B1 141.5mm/5.572 23.75mm/0.935 51.00mm/2.008 21.97-21.98mm/.8649-.8654
F22B2 141.5mm/5.572 23.75mm/0.935 51.00mm/2.008 21.97-21.98mm/.8649-.8654
F23A 141.0mm/5.551 19.81mm/0.780 48.00mm/2.008 21.97-21.98mm/.8649-.8654
H22A 143.0mm/5.633 23.75mm/0.935 51.00mm/2.008 21.97-21.98mm/.8649-.8654
As you can see the H22A are are 2.0mm longer stroking the motor.
Old Aug 22, 2011 | 02:22 PM
  #82
g22cd5's Avatar
Supper Moderator
haha I know my F/H series engines now
Old Aug 22, 2011 | 02:28 PM
  #83
g22cd5's Avatar
Supper Moderator
ummm yes sir they are the same...
https://www.hondaaccordforum.com/for...e-specs-33975/
read and learn
I know this for a fact since I have owned both h23 and f22 engines. Also had a few h22's but that's off topic.
I spun rod bearing on my h23 and use my whole f22 crank rods and swapped the pistons over. They are 100% the same I promise
Old Aug 22, 2011 | 02:37 PM
  #84
g22cd5's Avatar
Supper Moderator
you know the list of specs you posted didn't even have the h23 specs??
If you are trying to compare the h22 then yes there are some differences
Old Aug 23, 2011 | 09:41 AM
  #85
twoj1's Avatar
Sorry for the confusion. I was never talking about H23. I was talking about F22/ H22. You seem to know what you are talking about. let me ask you this. Are the H22 rods better then F22. I look at this for myself and am getting mixed feelings about it. I am currently building a F22 for boost( I plan on 15psi max). I don't want to cut my self short while I have the motor torn apart. I'm trying to do it right. goal 300 WHP.
Old Aug 23, 2011 | 09:50 AM
  #86
g22cd5's Avatar
Supper Moderator
the OEM h22 rods and little more "beefier" than the f22. I see ppl useing both of them. When I had my boosted f22 mine was pretty much stock. I use a h23 intake manifold and everything else on the engine was stock. I made little over 300hp and a good amount of tq.
But if you want to do it the right way get bisimoto f22 rods and piston combo(bisimoto.com). You will need to bore over by 1mm. If not he has a less expensive set that you won't have to over bore you can retain the stock 85mm bore.
Head work will be a big plus. port and polish the head and the intake manifold (make sure to use a h23 or f22a6 intake manifold NOT the f22a1/4). 3 way valve job. Bigger TB port matched (you will want to do that with the port and polish)
Old Aug 24, 2011 | 08:05 PM
  #87
Tek310's Avatar
say bro, i have a thread open in the engine and internal section. read up
Old Aug 25, 2011 | 01:56 PM
  #88
twoj1's Avatar
Thanks for the heads up.
Old Sep 11, 2011 | 09:10 PM
  #89
noahkeeberCD5's Avatar
f22b2 non vtec is great for a turbo, h22, not so great. but you gota weigh your options, would you rather get a turbo on the F and always wonder when its gona blow? or get an h22 and have the power its built for. h22 all the way
Old Sep 12, 2011 | 10:14 AM
  #90
twoj1's Avatar
I’m not concerned with blowing the ENG. I am building it up, new rods and pistons and head work. The goal is only 300 WHP. As for the F22 the only weak link is the rods and pistons. Looking into it, I have found. You get more bang for your buck with a F22 turbo then a H22 swap.
Cost.
F22 $400
Rebuild kit $200
Rods and pistons $600
Good turbo $1500- $3000
Total $2700- $4200
H22 $ 1800- $2500
Rebuild kit $ 200-300
Resleeve the block $400
Total $4500- $6800
As you can see F22 is half the cost.
