F22B2 non V-tec
Old Jan 14, 2009 | 04:08 PM
CBFeuls's Avatar
Default F22B2 non V-tec
Iwant to add a turbo and only boost my char about 5psi, is it possible to find supercharges that can do the same with less modifications? I am going to be installing new sleaves and rings but will be leaving the pistons and possibly the rods, should i replace the bearings? and should i do any headwork? new cam/ seals and are there roller rockers out there for the F22B2 to reduce friction and increase efficiancy? i also herd somone saying that you could bolt a new head onto the F22 block, how much work will be involved in that swap?
Old Jan 14, 2009 | 04:44 PM
jcocker03's Avatar
Default RE: F22B2 non V-tec
searchfor info on the G23 swap
G23=f22 or f23block + h22 or h23 head
Old Jan 31, 2009 | 12:04 PM
daemon44's Avatar
Yeah i'd like to know the same. I was actually wondering the same exact thing. You'd probably have to get fuel management and all that. Theres a thread on here about some cat putting a turbo on his and he pieced it together. I say go for it. I plan on doing it this summer and seeing how it goes myself
Old Feb 1, 2009 | 12:41 AM
19Accord97
I would just turbo it. Assuming your compression readings are ok, a stock F22B2 can handle about 6-8 psi.
martinez289
Mar 1, 2013 06:33 AM
97AccHondaMan
Sep 18, 2009 11:19 AM
EmTeeKay
Apr 20, 2009 04:36 PM
Custnam
May 6, 2008 10:40 PM
94Honda
Jul 25, 2007 01:56 PM
