old motor + turbo ='s
say u have 160,000mi. adding a turbo would be a.... good or bad idea?
RE: old motor + turbo ='s
First, get rid of the Bosch plugs before they fry your ignition coil, then post compression test numbers for us to evaluate.
get under ur car and take out the oil pan, check the inside of the engine, if it looks clean... then that's good (this is just one of the things to do, not the only one)... also follow falkore's advise... get NGK. make sure the timing belt is in good condition, and check the the pulleys, also make sure u have a good tranny. at least in good condition. uuuhhhhmmmm.... i think that's it...
A transmission cooler is a must for a automatic transmission. Failure to get one, if you do turbo your car will make your tranny wear out prematurely.
and use of the search function on the site..... cause failure to use it adds needless repeat questions and needless repeat answers and constant showing that you dont read forum provided information ^_^
well im working on getting the new plugs I just need to go into town and get them. but my compression is something like 161,158,160,162 I did it like 2 weeks ago and just had all new belts including TB and TB tensioner all of it. soooo
Compression #'s look good.
19Accord97: do u know whereI canget a GOOD tranny cooler? i've seen a few and ask around and no one had a good answer, so i just wanted to know if u knew
P.S: i did my research, and been looking for one for 5 months now, so im pretty desperate right now... |
www. summitracing. com
there was a thread about trany coolers a month ago as well which always pointed to a hayden 405 which you can get off amazon for 35 bucks
