turbo?
Old Nov 3, 2009 | 01:06 AM
4dooraccordex's Avatar
Default turbo?
im pretty sure i have asked before, but i have a 94 accord ex, F22B1, with 176,XXX miles on it, would it be ok to boost it, or should i just get a new engine and boost it, i really dont want to get the H22, its too common.
Old Nov 3, 2009 | 08:53 AM
Can't tell you 'cause I can't see the engine from here.
94 with 30,000 miles, burning oil, compression anywhere between 3 & 60 psi, then NO. Don't boost.
94 with 300,000 miles, good compression, not using oil, clean inside, then go ahead.
(it's not about the miles)
Old Nov 3, 2009 | 09:48 AM
its a good running engine, it doesnt burn oil, and it was just worked on, new seals, and gaskets, so i guess there shouldn't be a problem
thanks
Old Nov 3, 2009 | 05:45 PM
KevinAccord's Avatar
first of all, i think you should have posted this on the turbo section.
Second, if the engine is ok, then there should be no problem w/ boosting. my car was @ 120k when i boosted it. i would recommend to do a compression test first and find prices on turbo's and get to know you car and the turbo system setup pretty darn well. then go ahead and get to it. does it have a MT or an AT?
Old Nov 4, 2009 | 08:06 AM
Originally Posted by KevinAccord
first of all, i think you should have posted this on the turbo section...
Good idea, I'll move it over there. (Glad I thought of that... ;-)
Old Nov 4, 2009 | 11:48 AM
yeah, i should have posted it there, but it is a A/T, and its a vtec.
Old Nov 5, 2009 | 09:29 AM
have you done a compression test yet?
EDIT: how's the tranny fluid?
Old Nov 25, 2009 | 11:09 AM
Turbo_Accord_2010's Avatar
sup people,
im having a problem with my Mass Air Flow sensor. it trip the check engine light evry once and a while. i was tunnel blasting and at around 130mph it came on. is there a MAF thats tuned for a turbo charged f22b1
Old Nov 25, 2009 | 11:32 AM
00AccordLX5spd's Avatar
Registered User
^ you need to start your own thread instead of hijacking this one
Old Nov 30, 2009 | 08:25 PM
Originally Posted by Turbo_Accord_2010
sup people,
get a missing link....
moving on to the real thread...
any news on the oil leak?
