turbo from a eclipes to a 90 f22a
whould this work puting it on a 1990 accord f22a
ECLIPSE TALON 95-99 DSM T3 T4 TURBO KIT +RACE RADIATOR
Completed DSM T3 T4 Turbo Upgrade Kit * 1Year Warranty Item number: 8075028755 Starting bid: US $649.00
Buy It Now price: US $655.00
DSM T3 T4 TURBO UPGRADE KIT (300HP)
Brand New High Quality TO4E Turbo.
Stage-3 Turbo T3/T4 Compress .50/.63Turbine/.57trim.
CNC Machined Flanges 4Bolt Designed fit most After market Mainfold .
25 to 35 Psi Peak Power Performance Output Capability.(factory warranty)
Designed Usable for internal Gate Applaction. And/Or Use A T3/T4 With An Internal Actuator.
T3/T4 TURBO MANIFOLD (Competable with any AC/Power Steering Wheel)
High quality Stainless Steel turbo manifold for those who are piecing together their own turbo kits
The manifold and turbo are the most important part of the turbo system
Do not worry about whether your AC and power steering will work with other manifolds on the market
AC and PS compatible, and use by some of the top names in turbocharging
With 1Year Warranty from our our store.
Fitment: (Please read carefully or email us make sure kit for you car)
- Fitment of Manifld:1990-1998 Eagle Talon, 1990-1999 Mitsubishi Eclipse,1991-1992 Mitsubishi Galant (DOHC 2.0 TURBO ENGINE)
-1990-1994 Plymouth Laser This will also fit:1990-1994 Eclipse/Talon/Laser with 2.0 liter non-turbo engine (4G63)
-This is designed as part of an upgrade to a turbo with the T3 or T3/T4 hybrid turbo flange. It will not bolt up to the factory DSM turbo without some type of custom-made flange adapter
FMIC * FRONT MOUNT INTERCOOLER +CHROME PIPING SILICONE/T-BOLT CLAMPS
Brand new front mount intercooler.
Light weight designed. Made of Aluminum.(Increase 10-20 HP).
All TIG Welded 6061 Aluminum.(PSi Drop under 0.2. Other Intercooler usually drop 2Psi Some are More).
Max PSi is 30 Up to 400HP.Core Size: 22"x9"x3"Inlet OverAll Size: 31"x9"x3"Inlet.
Come with 3year Warranty from our Store.
Chrome intercooler Piping Direct fit Silicone hose/T-bolt Clamps.
Made out of High quality of 6061 Aluminum Meterial Chrome finished.
Extra thick Piping 1/16 Inches.
Increase 40-60% Air flow When Compare with other Piping
i believe the turbo manifold wouldnt bolt up and the down pipe wouldnt line up, then you have to deal with the fact that the charge piping is setup for an talon/eclipse, but drop a link for it so there can be a better view
and depending on the turbo manifold you would be dealing with the turbo being up against your radiator fans
hi my name is terry and i have a 90 accord i have that dsm setup in my car its good for about 350hp with internals it does not just bolt up you have to drill the manifold and make a custom down pipe if you want to know how to do the sutup IM me at terrible686 or email me at terrible686@aim.com
this is were i got the idea http://cgi.ebay.com/ebaymotors/ECLIP...spagenameZWDVW
well guess what, i found a kit, lol, it is costly thought but they do make them for my car http://www.modacar.com/Merchant2/mer..._Code=MODAFOIN
http://www.modacar.com/products/Hond...induction.html
you want to go based on that link because it shows accord specific.
You dont have to upgrade or piggyback the ecu unless you plan on going for more then 6psi or so, but beyond 10psi you need to upgrade the rods and pistons
premade kits save you the time of hunting and have an instruction manual but you can easily save over 1000 by hunting for the parts yourself
what about this one
http://cgi.ebay.com/ebaymotors/14b-t...QQcmdZViewItem
