Turbo help
Old Jun 5, 2011 | 05:28 PM
chrw's Avatar
Default Turbo help
i have an 09 coupe 2.4l. ive picked up a 70mm hks turbo for a good price, im not to sure of the proper things i need but im only going to run 5-8psi boost so i dont have to do a rebuild. im looking for help in the parts i need:
-intercooler
-turbo
-manifold
-blowoffs
also do i need a timer and controller for running small boost?
what else do i need and is it best to make my own piping or order some off ebay? thanks
Old Jun 15, 2011 | 04:57 PM
g22cd5's Avatar
Supper Moderator
I don't want to sound mean...but you have ALOT of researching to do. ALL the info you need is right at your finger tips..you just have to search the internet.
When going turbo there is ALOT of parts involved. I would recommend you search for a few months on how a turbo system works and the type and brand of parts you want to use and to steer clear of.
Also you want to research the extra maintenance and headaches that will be involved. (example: you have to let you car sit at idle for 3-5min when shutting her down so the turbo can spool down and cool off/The extra oil changes that will be necessary..and the list goes on)
Old Jul 1, 2011 | 09:02 PM
piggylover1985's Avatar
-intercooler
-turbo
-manifold
-blowoffs
Some more things to parts list : Waste gate, injectors,fuel pump, wide band, standalone system like AEM, Hondata or some other tunable ECM.
A turbo timer will help prolong the life of a turbo.
cortzeigler
Jul 30, 2012 01:58 PM
mamtsberg
Mar 17, 2010 09:15 PM
streetcustoms
Nov 1, 2007 11:31 AM
Accordn2dis
Sep 5, 2006 11:40 PM
flomasta
73
May 6, 2006 08:55 PM
