Upgrading fuel pump for nitrous
Old Jun 28, 2011 | 05:47 AM
Default Upgrading fuel pump for nitrous
So I am going to install nitrous on my car, and I want to install a Walbro 255 fuel pump to make sure there is enough fuel.
My question is I heard on the accords to replace the in tank pump you have to drop the gas tank, where as on civic you can just take it out the top. Can anyone confirm this?
If this is the case I think I will just install an inline fuel pump to work with the factory one.
Old Jun 28, 2011 | 04:27 PM
clutch811's Avatar
Yes unfortunately Honda went full tard and you have to drop the tank on the accords unless you cut a hole out yourself, which i do not recommend.
Old Jun 28, 2011 | 07:09 PM
Looks Like I'll be going in line then. Why did they have to make Accords so difficult? Have to drop the tank to replace the pump and hub over rotors? We got screwed.
Old Jul 3, 2011 | 08:23 AM
g22cd5's Avatar
Supper Moderator
Why not just get a after market fuel pressure regulator? I see ppl doing this all the time on the F series engines. Just crank up your fuel pressure so you run little richer while spraying.
Old Jul 7, 2011 | 09:40 AM
clutch811's Avatar
The stock pump can only handle that for so long and i think its better anyway to have a good fuel pump and a good tune when running nitrous.
rockhoundrob
Apr 11, 2014 11:41 AM
Westjoe64
Oct 15, 2012 12:11 PM
kissbally78
Jan 18, 2009 07:14 PM
23
Jun 5, 2006 07:02 AM
guitargod33
Mar 28, 2006 07:53 PM
