Noise in front suspension
None is going to know what the problem is for sure but we can give you some guesses
struts?( loose ball joints, upper and or lower,) radius rods bushings, sway bar bushing missing , etc etc ..
this is something thnat you or a shop have to chk out ,, raise the car up and chk all the frt suspension components
Also post this in the general help section, there you will get a lot more inputs
Mine is doing the same on driver side after new lower ball joints, new upper control arms with ball joints, new tie rod ends, brakes and rotors. Any advice
