front end suspension noise
Old Jan 18, 2012 | 10:25 PM
moey's Avatar
Default front end suspension noise
96 Accord 2.2L 4cyl
I did a brake job a couple weeks ago rotors/bearings/brakes I pulled the knuckle off and ball joints to remove it. The car now makes a sound like a old squeaky mattress, it makes the sound if you put your knee on the hood and push down. I thought the noise was coming from the lower ball joint so I loosened it popped the knuckle loose and then put it back together again. The noise went away for a couple days then came back.
The joint looked fine when I had it apart. I'm wondering if the onset of cold whether just didn't point out something that needs replacing. It has the original shocks/struts on it I'm wondering if this may in fact be whats making the noise and not the lower ball joint. Ive crawled underneath with the car on ramps and had someone put weight on the hood but I cant tell where its coming from.
Old Jan 18, 2012 | 11:55 PM
Spray the rubber parts under your car one at a time till you discover where it's coming from..
Give that a try and let us know what it was.
CrackWilding
Jun 27, 2012 01:39 PM
00accorddriva
Jan 2, 2008 04:05 PM
mpanelli
Dec 9, 2007 05:04 PM
corr04
Jul 25, 2006 11:32 PM
amp71
Aug 31, 2005 10:51 PM
