Off topic: Non-Honda fluid, etc.
Old Apr 16, 2015 | 02:21 PM
tirengolf's Avatar
Default Off topic: Non-Honda fluid, etc.
=shipo;358687]Using BG fluid (or any other fluid for that matter) is a very bad idea. Why? Because the Honda clutches in their automatic transmissions are designed for a very specific coefficient of friction, and it is HIGHLY unlikely other ATFs have the spcific friction rate necessary for proper clutch operation. Just because any given ATF *might* use a superior base oil does not in any way mean it is better for the transmission.
Long story short, if one has a properly functioning Honda transmission, using a non-Honda product in said transmission will most likely shorten the life of said transmission. If the transmission is already on the way out, you've got nothing to lose.[/QUOTE]
As I said I am not a engineer by any means and agree with you that you cannot go wrong with the OE fluids although with technology changing as it has I would differ with your opinion, I cannot believe that Honda could make a fluid that could not be duplicated by another company. Honda at some point has got to work on there cars I guess. I do not understand that a company like BG would issue a publication that says there fluid will work in something that actually has no factual data. My info is strictly on the job , I service foreign and domestic and have a large customer base as you could imagine after 55 years. I believe synthetic fluids are better today although some people may not. I would say if you went to a quicklube and they install a transmission fluid then add additive to make it Honda ATF-Z!- DW-1 no way, I see it all the time. And the Honda will always blow it out the pressure valve when it heats up. As I said this is a debate that neither of us CAN EVER WIN , when in doubt use OE, I think there is a better mousetrap today. I am not a fluid salesman or a stock holder in Honda or any oil company, just a guy who makes a living working on Autos. As I am sure would agree things have change so fast it is amazing. I am attaching some spec sheets from Honda and BG. Very interesting debate and it could go on and on. Have a great day
PS: 10 years ago I would agree with you 100%
Attached Thumbnails Off topic: Non-Honda fluid, etc.-20150416_131240-2-.jpg
Old Apr 16, 2015 | 02:27 PM
Old Apr 16, 2015 | 03:15 PM
shipo's Avatar
Attachment 14950
It sounds like you are confusing the quality of the oil component of various ATFs with their suitability for use in any given automatic transmission; just because any given oil uses a superior base stock does not in any way mean it will be suitable for numerous transmission designs.
Like I tried to explain before, it is the coefficient of friction built into the specific ATFs which enable the transmission to shift properly. If a given ATF is too slippery, then the clutches will slip too long during an engagement (and in some cases never engage at all), and as such wear out far too soon. Conversely, if any given ATF isn't as slippery as the transmission designers intended, the clutches could grab too quickly and can damage either the clutches or the surrounding mechanicals.
With new electronically controlled automatic transmissions, the situation can get even worse; in some transmissions, the computer senses a clutch engagement which didn't occur during a specified time window, and it disengages the clutch and tries to reengage it, again, and again, and again. Guess how long a transmission polluted with the incorrect ATF will last in a scenario like this.
As for the BG attachment, that they say their fluid is recommended for so many transmissions from so many makers, means it most likely isn't healthy for any of them; there is simply no way to have any one ATF which can work in such a wide array of transmissions.
Old Apr 16, 2015 | 06:35 PM
tirengolf's Avatar
You make a very good point, I would love to see data from a independent testing facility comparing the fluids. I am not aware of that research, If you have some I would love to see it. I understand completely what your saying. My feelings are a little different than yours, I am in the environment all day , sounds like you have some background in fluids. Do you feel that a Honda fluid could not be duplicated. I can remember the old tranny guys capturing the old FORD fluid and putting back in the vehicle, why was that. Were the clutches made out of different materials then than they are today. When in doubt use the OE. I will not be sucked into the web of if you own this vehicle you must run this fluid, That is exactly where they want you to do.This is a no win for me and you as the wide world web will show. If someone wants to go to Honda so be it. I said this was my point of view only. If you or anyone reading this does not agree to to Honda and buy there stuff. They say there brakes are better and you must replace and not turn turn there rotors, when indeed with the materials there metals are made of they are absolutely correct.I completely understand what you are saying, I just do not buy it. After all nothing last forever. I am a new poster here and certainly am not trying to lead someone down a road to tranny destruction, by the OE . Heat is the killer to all fluids as you no. You get it I can tell. If they have a product as you say, I am sure that would violate some Federal Laws. Although we will see in the near future The big guys HONDA, FORD CHEVY ETC will freeze all there info and we will be forced into going to a dealer for repair, no software will be available for there autos. That troubles me and should everyone in America. Gotta run , have a good one.
Old Apr 16, 2015 | 06:37 PM
tirengolf's Avatar
That is actually Lexus brake hold down clips sorry.
Old Apr 16, 2015 | 06:49 PM
tirengolf's Avatar
Transmission Elements Would this work in a Honda
Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid
A fuel efficient automatic transmission fluid recommended for GM, Ford and Toyota transmissions where lighter viscosity oil is required. Provides the same excellent protection and performance as AMSOIL ATF. Recommended for vehicles requiring GM DEXRON® VI, Ford MERCON® LV and SP, Honda DW-1, Nissan Matic-S and Toyota WS fluid specifications.
Old Apr 16, 2015 | 06:59 PM
shipo's Avatar
I'm sure Honda ATF is relatively easy to reverse engineer; that said, I don't believe I've ever seen an aftermarket ATF specifically formulated for Honda (and only Honda) transmissions. I have no idea whether that is because Honda has some sort of a trademark lock or other patent blocks on their DW-1 formulation or if other makers just don't see a big enough market (hard to believe).
Thinking about another maker with a fairly unique ATF formulation, Chrysler specifies ATF+4 for virtually all of their automatic transmissions; use something else and your transmission will most likely end up toast. At least in the case of Chrysler, they are also smart enough to license the duplication of that formulation so you can buy ATF+4 from Valvoline, Super Tech (Walmart), and many others in addition to the MOPAR brand. Honda may just have decided they want to be the only game in town.
Does that stop other manufacturers from saying stuff like, "Compatible with Honda DW-1"? I don't know, I'm not an Intellectual Property specialist.
Old Apr 17, 2015 | 06:41 AM
tirengolf's Avatar
Thinking about another maker with a fairly unique ATF formulation, Chrysler specifies ATF+4 for virtually all of their automatic transmissions; use something else and your transmission will most likely end up toast. At least in the case of Chrysler, they are also smart enough to license the duplication of that formulation so you can buy ATF+4 from Valvoline, Super Tech (Walmart), and many others in addition to the MOPAR brand. Honda just may have decided they want to be the only game in town.
Honda may just have decided they want to be the only game in town. ILLEGAL: Quote Federal Trade Commission Website=FEDERAL TRADE COMMISSION
CONSUMER INFORMATION
ESPAÑOL
Search form Search
MONEY &
CREDIT
Shopping & Saving
Buying & Owning a Car
Credit & Loans
Dealing with Debt
Resolving Consumer Problems
HOMES &
MORTGAGES
HEALTH &
FITNESS
JOBS &
MAKING MONEY
PRIVACY &
IDENTITY
BLOG
VIDEO &
MEDIA
SCAM ALERTS
Vea esta página en español
Auto Warranties & Routine Maintenance
Related Items
How to File a Complaint
Auto Service Contracts and Warranties
Auto Repair Basics
If you own a car, you know how important it is to keep up with routine maintenance and repairs. But can a dealer refuse to honor the warranty that came with your new car if someone else does the routine maintenance or repairs?
The Federal Trade Commission (FTC), the nation's consumer protection agency, says no. In fact, it's illegal for a dealer to deny your warranty coverage simply because you had routine maintenance or repairs performed by someone else. Routine maintenance often includes oil changes, tire rotations, belt replacement, fluid checks and flushes, new brake pads, and inspections. Maintenance schedules vary by vehicle make, model and year; the best source of information about routine scheduled maintenance is your owner's manual.
What is a warranty?
A warranty is a promise, often made by a manufacturer, to stand behind its product or to fix certain defects or malfunctions over a period of time. The warranty pays for any covered repairs or part replacements during the warranty period.
Do I have to use the dealer for repairs and maintenance to keep my warranty in effect?
No. An independent mechanic, a retail chain shop, or even you yourself can do routine maintenance and repairs on your vehicle. In fact, the Magnuson-Moss Warranty Act, which is enforced by the FTC, makes it illegal for manufacturers or dealers to claim that your warranty is void or to deny coverage under your warranty simply because someone other than the dealer did the work. That said, there may be certain situations where a repair may not be covered. For example, if you or your mechanic replaced a belt improperly and your engine is damaged as a result, your manufacturer or dealer may deny responsibility for fixing the engine under the warranty. However, according to the FTC, the manufacturer or dealer must be able to demonstrate that it was the improper belt replacement — rather than some other defect — that caused the damage to your engine. The warranty would still be in effect for other parts of your car.
Will using 'aftermarket' or recycled parts void my warranty?
No. An 'aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. A 'recycled' part is a part that was made for and installed in a new vehicle by the manufacturer or the original equipment manufacturer, and later removed from the vehicle and made available for resale or reuse. Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.
Tips To Avoid Warranty Issues
Here's how to get the most out of your vehicle's warranty:
Read your warranty. Often bundled with your owner's manual, the warranty gives a general description and specific details about your coverage. If you have misplaced your owner's manual, look for it online. Check the "Owners" section of your manufacturer's website.
Be aware of your warranty period. If problems arise that are covered under the warranty, get them checked out before the warranty expires.
Service your car at regular intervals. This is a good idea in any case. But for the sake of keeping your warranty intact, follow the manufacturer's recommended service schedule. Details are in your owner's manual.
Keep all service records and receipts, regardless of who performs the service. This includes oil changes, tire rotations, belt replacement, new brake pads, and inspections. Create a file to keep track of repairs; it will come in handy if you have to use your warranty. If you ever have a warranty claim and it appears that you did not maintain your vehicle, your claim could be denied.
Complain. If you think a dealer's service advisor denied your warranty claim unfairly, ask to speak with a supervisor. If you still aren't satisfied, contact the manufacturer or go to another dealer. You also may wish to file a complaint with your state Attorney General, local consumer protection office, or the FTC.
This article was previously available as Auto Warranties, Routine Maintenance, and Repairs: Is Using the Dealer a Must?
All transmission's will were out as we both no, I wonder how many fail with Honda fluid that we never hear about , the guy goes to Honda and they say your transmission is toast. Customer says go ahead and put a new one in . I have know indication that using a fluid that is a higher grade than what Honda requires causes destruction. I would like to see what Honda says about there so called on fluid application, I have been around this all my life sir. I will not buy end to the fact that Honda is the only fluid to run in there car, if I see the spec sheets and feel it is a quality product I should be able to try it. Who is to say Hondas fluid is not causing premature destruction of the transmissions , google Honda complaints, Trannys are at the top, most of the ones I have seen destroyed has Honda fluid in them. I change them all the time and have yet to have a problem if It is been done at correct times. I am doing a 93 Accord today, 123k transmission issue, as we know after they slip consumers think they can change the fluid and it may fix it, not true. I will let you know the outcome of this car. It almost sounds like the Michelin Honda PAX tire experiment that again the consumers were left holding the bag with. I am about to hang it up sir, retire, I am not for vehicle specific fluids because when that happens the consumer will have to carry every car back to a dealer and that my friend is not far to the consumer. I have people walk in my shop everyday and say I just left the dealer and LOOK at this estimate. That is what scares me. I know some dealers that are good and I know some that just hose people. We must stop the big from car specific diagnostics, Chrysler just changed to Siemens PLM software, 2013 and up, the module to hook up cost me 6500 plus 2000k a year license agreement. If you think it is bad now wait in 10 years unless we can get Big Brother to step in , this is unhealthy for the population. I really do not buy your theory, do you work for Honda, if so explain the PAX tire issue, I want to hear Honda's side of that one.
Old Apr 17, 2015 | 06:52 AM
tirengolf's Avatar
Do not misunderstand me , I like Honda vehicles, I have just heard about this tranny issue so much with consumers, it is almost weekly, I think there is a problem as a lot of other people do. Maybe a different fluid will cause longer life, this is a problem to others as well. Check out this link.Honda Accord and Civic Transmission Failure
Old Apr 17, 2015 | 07:36 AM
While I believe all the stuff about Honda ATF having a different mix of friction-modifiers, and not being the same; I cannot believe that Honda is in the business of MAKING THE FLUID. Honda doesn't manufacture their own spark plugs (NGK) nor do they manufacture their own tires (Bridgestone & Michelin). I bet they don't manufacture their own engine-oil, brake fluid, or ATF either.
You'd think that someone would offer the ATF, just like a couple companies offer Honda-spec power steering fluid. I've just never seen it. And I don't believe it can possibly be covered by the "good for all-makes & all-models" labels on some fluids.
