POST YOUR Mileage
Old Nov 23, 2013 | 07:20 PM
  #531
Talking
Originally Posted by Honda_Lady
I will try not to stay away too long.
Good to hear that..
Old Nov 23, 2013 | 10:27 PM
  #532
ltl lifer's Avatar
Now have 102k on the '03 EX coupe and 5k on the '13 EX-l V.
All of the technology that is in this new car gives the car issues:
  • It has the ECON mode. True it saves gas and I only use it on the road and gets EXCELLENT mileage on the road for a V6. Around town the power is needed so I kick off the Econ but when you let off the gas it feels like an engine brake kicks in. Also, when you punch it there is a hesitation.
  • Ride is tight. Hard to drink a beer on a bumpy road LOL!
  • The Display will go from bright to dim for no change in lighting (under an overpass, etc.) Again, with so much technology you can't expect perfection.
When I take it in shortly for service, these issues will be addressed.
Old Nov 24, 2013 | 10:41 AM
  #533
sldl04's Avatar
48,000 on our '09 Accord EX sedan. My wife loves it and won't trade it for a new one...even though the dealer wants us back to trade a year later. No problems whatsoever at this point, although probably will need new tires next year (still have factory Michelins on it).
Old Nov 26, 2013 | 01:20 PM
  #534
rclc's Avatar
Smile rclc
94 Accord EX with 210,000 miles. 5spd with orig. clutch plate. Still running strong.
Old Nov 26, 2013 | 04:00 PM
  #535
djaycardona's Avatar
94 Honda DX with only 93 almost 94
Old Dec 8, 2013 | 11:15 AM
  #536
Frugalhondaguy's Avatar
Just turned 180K on a 2000 Accord EX with a 5 MT. One set of brakes at 120K miles, changed the TB and water pump, two batteries replaced, O2 sensor replaced, several oil/filter changes and many tires. Original clutch still rock solid.
Old Dec 11, 2013 | 05:02 AM
  #537
kobiewan's Avatar
162k miles on my 99 accord. original engine and automatic trans
Old Dec 11, 2013 | 05:15 AM
  #538
kobiewan's Avatar
Originally Posted by Lou M
1999 Accord LX Sedan 4cyl Auto, with 408K miles, original owner. A lot of original parts (engine, transmission, exhaust (minus cat), struts). Unfortunatley, it's time to put it to rest. Getting a DTC P1457 (system fuel leak) and a smell of gas. My mechanic says there is a leak up near the top of the tank. The tank needs to be dropped to find the cause. Too much involved to do this (drop the rear end, remove exhaust from cat back, disconnect the rear brake lines). With other things needed (tires, brakes, timing belt) it's time to let it go. It was a great car for 13 years. Just bought a 2002 Accord EX V6 Auto Sedan with 139K miles. I hope I have just as much luck.
Sad to hear that. I have the same code and it is actually a very simple fix. its a small valve right underneath the car. open vent shut valve. easy to fix. otherwise it would have been your canister. shame that you gave up your car for something rather simple to fix
Old Dec 26, 2013 | 04:35 PM
  #539
John T's Avatar
Default 2002 Accord ES
212,000.
Same engine, tranny.
Old Dec 26, 2013 | 06:00 PM
  #540
kobiewan's Avatar
John is it an automatic?
