POST YOUR Mileage
Old Nov 3, 2014 | 04:59 PM
  #581
Frugalhondaguy's Avatar
Originally Posted by mpanelli
286,000 miles.
The only thing I have done to this car is
- 3 sets of tires
- brakes
-plugs
- oil / filters
- Front wheel bearing
Still has original struts. replacing struts, upper and lower control arms this weekend.
This is why I buy Honda!
I'm still on the original suspension at 200K on a 2000EX. No wheel bearing problems yet. So far 2 timing belts, 1 water pump, 3 batteries, replaced both O2 sensor's, brakes at 110K (still had plenty of pad remaining), tires 3 or 4 times, plugs once 110K (they still looked good), plug wires, cap/rotor, last repair was a clutch slave cylinder. Replaced it with a Dorman part for $20.00 and an hour of my time. I agree these cars last forever.
Old Nov 4, 2014 | 06:22 PM
  #582
Dakotademon7's Avatar
I have a 91 Accord with a think 163000 if I remembered right.
Old Nov 4, 2014 | 11:48 PM
  #583
rclc's Avatar
Default Still Running
220,000 miles on my 94 Accord
Old Nov 5, 2014 | 06:34 PM
  #584
woody31's Avatar
Almost A Senior Member
Default miles to go
just rolled 170000
Old Nov 5, 2014 | 06:35 PM
  #585
woody31's Avatar
Default miles to go
[IMG][/IMG]
just rolled 170000
Old Nov 6, 2014 | 09:15 PM
  #586
coolaccord's Avatar
just got to 212,000 a couple days ago....planning to keep it well past 300K
Old Nov 10, 2014 | 08:45 AM
  #587
maroonwhitepinstripe's Avatar
Default miles, misbehaving CPU? test charging system first.
i think its close to
199867 something like that
so since iposted last ive done
axles
bearings
swapped in spare spindles with all new stuff.
valve cover gskt
egr ports with new little caps,
used long metal tapping screws and pull with
claw hammer, easy peasy.
ACCident!! in june
woman hit me on pass frnt wheel
as i was turning right into a parking spot
woman's ins co. maintains she was passing me using
the right turn lane. well as it turns out
there is no right turning lane...
any way after that
replaced pass caliper and old spindle that i had.
should have seen repair person's face.
"you have a spare spindle??
shouldn't yah think about replacing the car?"
No, i said.
pays to go to pick and pull.
then auto transmission probs came
safe mode 2nd gear
thought it was the water coming in from the dash somewhere
soaking, shorting cpu. cpu says "gear selector sensor circuit"
pulled carpet and then it behaved
then nope back to 2nd and third only
which actually gave me some better mpg.
then barely made it home
bad battery no charging
tested charge on battery with car on started to drop 11.87-.76-.52 so on.
then swapped out alternator,
parts America tested, says its fine...
got a new one anyway,
now trany cpu works fine
100 miles no prob.
bad voltage = bad cpu behavior.
if have a malfunctioning cpu
test charging system.
Old Nov 10, 2014 | 08:53 AM
  #588
what to expect
check
count on suspension components.
altenator out put
make sure its constant.
cooling system
little cooling system hoses
radiator
if have a buggy no start sometimes usaualy rainy
check solder on fuel pump relay all it takes is a tiny crack.
just heat and reset solder.
Old Nov 11, 2014 | 02:24 PM
  #589
rclc's Avatar
Originally Posted by Cstp
Hey
just wanted to get an idea of your Mileage its KM please say so beside and if its miles same thing
Thanks a bounch (bunch( maybe?
Your Spell Checker WheelBrokerAng
220,000 94 Accord ang going strong
Old Nov 27, 2014 | 03:46 PM
  #590
07_Accord_SE's Avatar
I just passed 135,000 miles on my '07 going strong except the fuel economy is dropping for some reason.
