06 Accord Broken Driver Strut
Old Sep 18, 2008 | 09:25 PM
BucWild
Default 06 Accord Broken Driver Strut
First Time Poster and Tuning Newbie hereso please be gentle.
I had a setof Eibach Pro Kit Lowering springs put on my car about6 months ago and my tires have been wearing real bad on the inside even after an alignment. I mentioned that the driver front hits hard when I go over bumps and was told the strut was broken. The technician told me I will have to have them replaced. He said the part from Honda was about $500 but I should probably look online. I find Honda Shocks everywhere but no stuts. What is the recommendation for replacement performance struts. Additionally, the tech mentioned that I will want to put a camber kit on to be able to truly align the car.
So, if I have about $1000 to spend what are the recommendations?
Thanks
Old Sep 19, 2008 | 08:30 AM
falkore24's Avatar
Default RE: 06 Accord Broken Driver Strut
Bilsteins for the best performance, Koni adjustables for the custom ride.
Old Sep 19, 2008 | 10:18 AM
finch13's Avatar
Side note: shocks and struts are both interchangeable term for dampers. Try the tirerack.com, it's very easy to use and have fairly competitive prices. They sell both Koni Sports (yellow) and Bilstein Sports and HDs, along KYB AGX and GR-2's.
Old Sep 19, 2008 | 10:55 AM
BucWild
Thanks to both of you. Can you tell me about the camber kits as well?
Old Sep 19, 2008 | 11:01 AM
finch13's Avatar
Shouldn't need a camber kit with Pro-Kits... I had those springs and I didn't need a camber kit on my car... even with 240 treadwear tires I never wore them unevenly. Take your car to a different shop for the alignment. If you do, it's only for the rear and I would go with Ingall's or SPC, both in the $200-$300 range.
Old Sep 19, 2008 | 12:48 PM
BucWild
As far as wear on the inside of two front sets tires you think just bad alignments both times? Could the broken strut have caused one set?
jza240sx
Apr 30, 2013 04:14 PM
john402052000
Sep 25, 2010 05:55 PM
Robert Bob
Sep 14, 2009 10:14 AM
ndp
Jun 7, 2009 05:23 PM
pgopalak
Dec 17, 2004 03:30 PM
