1992 Accord LX 2.2 ( Sway bar adjustment ?'s)
Old May 28, 2019 | 01:40 PM
Slammed92Acoord's Avatar
Post 1992 Accord LX 2.2 ( Sway bar adjustment ?'s)
Bought this car already lowered. It eats up tires really bad in the rear. Has aftermarket coil overs... Wanted to know if i can maybe drill a hole in the sway bar, (maybe?) and adjust it to the right degrees so the tires will wear even...?? Also i noticed while looking at the coil overs on the rear the spring is under the adjusting part of it, is that right ?? or is it suppose to be on top like the name says, coil over???
Old May 28, 2019 | 02:19 PM
First, you'll have to know what the rear angles are (camber & toe). The sway bar doesn't really control those angles, so the adjustments would be in the suspension not on the sway bar.
As far as the spring being over or under the spring-seat, that's not what the term "coilover" is about. What brand are they? Someone familiar with those would have to say what's the correct way they should be assembled...
Old May 28, 2019 | 09:40 PM
Ok thanks for the advice. How would i figure the right angles? (what tool, if any)... And maybe im calling it the wrong name... stabalizer? rear a frame? Also the coil overs on front of car are on top of adjustment but on back its under? Box coil overs were bought in was in trunk but no name on any of the parts lol tried to trace the seriel # but cant find it....
Old May 29, 2019 | 01:26 PM
Found the place coilovers came from...OTC INC. Chino Ca??? ever heard of em?
rob3201
Jan 19, 2014 01:09 PM
Nightbreeze
Dec 17, 2009 09:04 PM
street_racer7112
Sep 16, 2007 06:51 PM
accords own
Aug 15, 2007 01:01 AM
sekander007
Sep 22, 2005 12:03 PM
