2006 banging over bumps
Old Mar 3, 2018 | 09:06 PM
Bob2006's Avatar
Default 2006 banging over bumps
Have a 2006 that just hit 100,000 miles.
The potholes seem to have taken their toll.
Replaced the front struts a while back.
The car really rides rough over bumps and seems to be getting worse.
Is this the rear struts or is something else going on here?
Not sure where to start.
Thanks in advance for any help.
Old Mar 5, 2018 | 02:27 PM
Check ball joints, lower arm bushings, sway bar links, and wheel bearings for damage (looseness or broken). Noise is usually result of a broken or badly worn component.
Old Mar 5, 2018 | 02:31 PM
Seanjordan20's Avatar
Something that is always over looked are the sway bar links. If you hear a clunk hitting holes then more than likely that is your issue. Also check and make sure you ball joints are in good shape.
Old Apr 22, 2018 | 05:25 PM
wag928s's Avatar
I just traded in an Accord 06 Coupe, 6 speed manual w/Navi. I had the same issue. Replaced most everything in the front end trying to find the "Klunk". It turned out to be the axle shafts. Replaced them, and it was gone. End of that. The joint was loose, going over ridges in the road, slight bumps, it was klunk. Put car up on ramps, grab the axle the best you can in the middle, or use a breaker bar, and see the play. Apparently, this is pretty common problem. Suggestion: Spend the bucks, get the original Honda shafts, less problems.
dculp001
Jan 7, 2015 07:39 PM
maro
Jan 7, 2008 01:06 PM
thunder_x
Dec 10, 2007 10:24 AM
manual123
Dec 1, 2006 01:46 AM
deserthonda
Sep 5, 2006 02:57 AM
