92 accord rotors fit 94 accord
yes they will work. All 90-97 accords use the same rotors and suspension.
The only thing that you might come across is the ABS systems. But that will not be a issue you just don't hook up if you don't have ABS. Now if your 94 is does have ABS you need to make sure that the 90-93 accord has ABS to make this work. Not many cb7s have ABS only the EX and SE from what I remember. The way t tell is if the car has rear disk brakes If so then it has ABS If drums in the rear no ABS.
98accordman
Oct 24, 2010 10:34 PM
deserthonda
May 12, 2006 04:06 AM
