Are camber kits needed????? if installing coilovers
Old Feb 16, 2010 | 05:25 PM
soysauce49's Avatar
Default Are camber kits needed????? if installing coilovers
I have a 2007 EX-L V6 coupe auto. trans., bone stock... I am looking to buy the TEIN basic coilover set, but I was wondering if i need to buy a camber kit as well. any advice would be nice, thanks.
Old Feb 16, 2010 | 05:46 PM
jasonfridlund's Avatar
well, it depends, up to about an inch of lowering, you should be ok. your tire wear shouldnt be much worse. past that, probably
Old Feb 17, 2010 | 12:49 AM
soysauce49's Avatar
ight thanks man
Old Mar 13, 2010 | 01:37 AM
metaender's Avatar
Yup just as jasonfridlund said.
Depends on how much you lower it, sometimes it wont be enough to affect your tires. Also if you have a mechanic install them you could always have them check your camber for ya.
Old Mar 13, 2010 | 02:41 AM
Talking Hi Member
You must get your car aligned after you get your Coil-overs installed..your alignment man will be able to tell you if you will need camber kits on your car..So in other words..have that extra money ready before you take it to the alignment guys.just in case you need camber kits...
Attached Thumbnails Are camber kits needed????? if installing coilovers-camber_largedad.jpg
thunder_x
Jan 23, 2008 10:01 AM
19accord95
Feb 11, 2006 02:06 AM
dinzer
Aug 11, 2005 11:42 PM
g6ex6
Apr 7, 2005 05:25 PM
