chopping or heat up springs???
Old Dec 23, 2006 | 08:13 PM
foxracing31702's Avatar
Default chopping or heat up springs???
i have a 92 accord EX and i bought tokico HPshocks and springs. they say its going to lower it 1.25 but i dont think its going to be enough. what do you think about chopping them or heating them up to lower it down more...
Old Dec 23, 2006 | 09:16 PM
RTexasF's Avatar
Super Member
Default RE: chopping or heat up springs???
That's a hack way to do it so don't. Use the proper items required or be satisfied with the 1.25" drop
Old Dec 23, 2006 | 09:44 PM
mamarotta's Avatar
cutting them is prob the most sensible but if you torch them u have just changed whats called spring rate and u might not even be able to support the car let alone handle the road. truthfully thats not the way u wanna go unless u own a junk yard and have hundreds of springs. the u are just passing time. nothing else.
Old Dec 23, 2006 | 09:46 PM
poser_pilot6
Dont be ghetto. How low do you really want to go? I think 1.25 is just about perfect for a daily driver. Low enough to look good and handle better, not so low that you scrape all over the place.
Old Dec 24, 2006 | 02:20 AM
Ya dont want to cut or heat the springs, it changes the molecular structure of the steel and makes it un safe.
If you want to go lower then I suggest you think about
going to coil-over springs..
Old Dec 25, 2006 | 07:16 PM
Tony1M's Avatar
If I were going to cut a spring, I'd use a cut-off wheel and be applying cooling water to the spring andcut-wheel as the cutis being made. If the spring metal right at the cut is kept atnormal temperature during the cut, the spring's "temperament" will not change.
Of course any change in the overall length of the spring will definitely cause the car tonot absorbbumps as well. For example, imagine what would happen if you cut the spring in half.
Old Dec 30, 2006 | 12:10 AM
solobaric6800w's Avatar
even if you did above the spring is still going to travel the same wheather the spring normal size or smaller
Old Jan 2, 2007 | 09:11 PM
sir_nasty's Avatar
a side note on the whole spring cutting thing as well.... most springs actually have a dual spring rate, meaning the bottom 2/3 compress more quickly than the top 1/3, so if you cut it you will change things pretty drastically, and if you cut a piece off the top vs. a piece off the bottom that makes a HUGE difference.... I don't recall if honda does this on OEM springs or not... but most aftermarket ones do... I Know H&R does and so do most bilsteins
Old Jan 2, 2007 | 10:10 PM
poser_pilot6
All I know is that I have ridden in cars with cut springs, and the ride is HORRIBLE. I dont know why someone would cut the springs instead of saving up a little money and doing it right. What does it cost for a set of springs, like $200?
iskate604
Sep 8, 2013 07:29 AM
skijour
Aug 15, 2012 08:31 PM
Cessna172
Nov 5, 2010 01:22 PM
imthehink
May 4, 2008 12:06 AM
Newdude
Feb 4, 2006 05:53 PM
