DIY rear and front upper strut bars
Old Aug 2, 2007 | 11:39 AM
ohsmustangs09's Avatar
Default DIY rear and front upper strut bars
i have a 95 accord coupe ex and i need help with installing mainly the rear upper strut bar....any info greatly appreciated, thanks!
Old Aug 2, 2007 | 02:41 PM
sir_nasty's Avatar
Default RE: DIY rear and front upper strut bars
Peel down/back the carpet, get a lineup on where the bar will go through the carpet to attach to the upper part of the strut tower. Then remove the ends off the strut bar that bolt to the top of the strut tower. Now you just have a bar, cut an X or + into the carpet at the point that the bar is going to pass through it, slide the bar in, re-install the ends that bolt on, remove the 3 upper strut tower bolts, slide the end of the bar over the bolts, re-install the bolts and torque to specifications.
Old Aug 2, 2007 | 04:09 PM
Seems easy enough, thanks!!
Old Aug 2, 2007 | 05:25 PM
sir_nasty's Avatar
It should be fairly straight forward, I've put them on a few civic's without issue.
Brent Paul
Jun 13, 2014 06:23 AM
big_pd
Mar 25, 2011 10:16 AM
AWeb80
May 2, 2008 01:30 PM
trukid21
Mar 28, 2007 01:22 AM
aka1109
Jan 10, 2005 02:19 PM
