Friendly tip for installing lower ball joint
Old Sep 10, 2011 | 05:30 PM
Tek310's Avatar
Default Friendly tip for installing lower ball joint
Lube the inner race on the spindle
But the key things is stick the new ball joint in the freezer until it is ice cold. It literally slides in with finger pressure and then expands in the spindle as it heats up, locking it in place.
Hope this helps future jobs!
Old Sep 11, 2011 | 12:13 PM
Default ** hey ! **
Now that's a good idea..there's also a product that you can buy at your local parts store called Freeze Up..about $8.00 bucks a can..you can use it under the car if you don't have a Freezer Close By...
Later...
Attached Thumbnails Friendly tip for installing lower ball joint-3_9tiq8airforcerules%5B1%5D.jpg
Old Sep 11, 2011 | 01:21 PM
Peli's Avatar
This should come in handy! I'm actually planning to do mine sometime mid-late this month. Are you sure freezing the piece and bringing it back to temperature so abruptly won't affect its integrity?
Old Sep 12, 2011 | 09:02 PM
Freezer, OK. It gets colder than that in winter in many parts of the country.
Now I wouldn't use liquid nitrogen or anything like that. Metal can get brittle at those temperatures.
Old Aug 26, 2013 | 10:17 AM
sgull's Avatar
I tried it and it didn't work for me. Put the ball joint in the freezer overnight. Put a little grease inside the race and tried to slide it in with finger pressure. No go. Not even a little ways.
razcob
Apr 29, 2008 10:42 PM
hatzipri
Nov 10, 2007 10:03 PM
shome
Aug 16, 2007 10:54 AM
PAhonda
Jul 10, 2007 04:40 PM
Hondaccord
Nov 4, 2006 06:30 PM
