FRONT WHEEL GAP?
Old Apr 19, 2007 | 08:20 PM
Chaqui04's Avatar
Default FRONT WHEEL GAP?
Can someone help i have put eibach prokit springs /tokico blue shocks and ingalls camber kit and i have more of a gap in front than the rear but the car sits even . What option do i have to lower the front more. Car sits in front 3 fingers and the rear 2 fingers i can fit between the fender/quaterpanel and the tire. Now originally i had just put the springs and the car was sitting higher in front so i thought that i need to do it right by putting shocks and camber kits but i'm still having the same issue .
[IMG]local://upfiles/8971/57A1AFA868914B31A78537CC6D5FA679.jpg[/IMG]
[IMG]local://upfiles/8971/0F1FB313F8DD4000A42740DF5002806C.jpg[/IMG]
[IMG]local://upfiles/8971/F3DDC4C8BEF148D2BED3558C4E3CD004.jpg[/IMG]
Old Apr 19, 2007 | 10:50 PM
stevent's Avatar
Default RE: FRONT WHEEL GAP?
let it adjust over the weeks, im sure the springs will lower the car a little bit more if you let it sit for a while.
Old Apr 20, 2007 | 01:04 AM
trukid21's Avatar
i agree also with stevent, i have the same springs but with kyb shocks and at first it looks like there was a pretty good gap on the front, but after awhile it actually settled down a bit.there is still a gap but it is not as bad as before.
Old Apr 21, 2007 | 12:36 AM
magana408's Avatar
same here i have kyb agx with eibach sportline spring i installed them like almost 2 years ago and still have the big gap in the front
Old Apr 21, 2007 | 03:44 AM
stevent's Avatar
well the prokits dont give you much of a drop because it only lowers your car by about 1-1.5'. If you wanted more of a drop, your should have gone with coilovers because it will allow you to adjust the height to your liking.
Old Apr 21, 2007 | 10:41 AM
Chaqui04's Avatar
Ok thanks.
Old Apr 21, 2007 | 10:55 AM
Chaqui04's Avatar
Well i was hopping to have less of a gap up front . Thanks guys .
[IMG]local://upfiles/8971/6268C1555952404486A3142E406675C9.jpg[/IMG]
Old Apr 30, 2007 | 01:40 PM
otsb708's Avatar
Almost A Senior Member
Nice car by the way~!
gshock
Feb 23, 2009 12:24 AM
97SE
Nov 20, 2007 12:22 PM
trukid21
May 2, 2007 03:55 AM
trukid21
Apr 29, 2007 01:46 PM
19accord92
Apr 10, 2006 03:52 PM
