To grease or not to grease?
Old Oct 10, 2012 | 08:31 AM
jkowtko's Avatar
Almost A Senior Member
Default To grease or not to grease?
I am preparing to replace more bushings in the rear suspension of my 1996 Accord EX sedan, am looking at the CD7 manual and noting all of the places in the suspension where silicone grease is and is not indicated.
I can understand greasing the slipping rubber bushings such as the front sway bar link ends, but am wondering why some of the non-slip bushings also have grease indicated for them? Specifically the rear lower shock mount bushings and the rear lower control arm bushings. These bushing press fit into their containing arm/knuckle, the attaching bolt is tightened firm around the inner collar, and the rubber twists with suspension travel. So what am I supposed to be greasing? Just the face of the rubber?
I also wonder why some slip bushings such as the sway bar mounts do not have grease indicated for them?
Old Oct 11, 2012 | 01:26 PM
Um... yeah, I guess that's confusing to me too. I'd expect you to grease the rubber parts that actually rub & slide. Not the ones that are molded onto their brackets & they just flex.
Old Oct 28, 2012 | 07:48 PM
How many if any of them have some kind of grease fittings.?
Old Oct 28, 2012 | 09:48 PM
Probably none of em have grease fittings. These are things like the anti-roll-bar pivot bushings.
voteforpedro
Oct 5, 2009 01:24 PM
new2accord
Apr 15, 2008 08:04 PM
brittanym06
Nov 10, 2007 02:08 PM
mck52689
Jul 17, 2007 05:08 PM
im4an2idiot0
Jun 17, 2006 04:19 AM
