installing coilovers on a 1991 honda accord?
Well that's a pretty broad question. Lots of companies make coilovers for your Accord. Installing the coilovers is actaully fairly simple.
For the front:
1)Remove the wheel
2)Remove the brake hose from the shock assembly
3)Disconnect the sway bar from the lower control arm
4)Support the lower control arm with a jack and remove the damper fork pinch bolt
5)Remove the damper fork to lower control arm bolt and remove the fork
6)Remove the three upper mounting nuts (located inside engine bay)
For the rear:
1)Remove wheel
2)Remove the trunk side carpet
3)Remove the two upper shock mounting nuts (inside the trunk)
4)Remove the shock lower mounting bolt
5)Pull the rear knuckle down and remove the shock
Install is reverse of removal for both front and rear
For the front:
1)Remove the wheel
For the rear:
1)Remove wheel
cb7
Jul 11, 2009 02:06 AM
thunder_x
Jan 23, 2008 10:01 AM
