Jacking up my 2006 Accord Problems...
Old Jun 6, 2009 | 05:12 PM
CYANiDE's Avatar
Default Jacking up my 2006 Accord Problems...
This may sound really noob, but I just can't find the right spot to place my jack to change my left rear tire. I found 2 points, which don't even raise the car even if the car jack is at it's max. I only see a few other places, but I fear that something will bend inward if I place my jack on them...
Any pics or good descriptions about where they should go?
Old Jun 9, 2009 | 07:16 AM
thebigone
Center front (cross member) or center rear of the car ( where the tow bar is) otherwise the lifting point for the front side will be just below the front fenders where the bottom of the door meets the bottom of the fender. On each you should see an indentation, between these indentations are the lifting points. For the rear sides it will be just below the rear door corner closer to the rear tire area. You should see these indentaion as well. Likns to some pics. Hope this helps.
http://i89.photobucket.com/albums/k2...u/DSC06905.jpg
http://i78.photobucket.com/albums/j8...JackPoints.jpg
Tony1M
May 8, 2011 02:23 AM
thunder_x
May 21, 2007 08:21 PM
j_man_honda
Jan 11, 2007 07:29 PM
wayneboard2
Dec 19, 2006 01:59 PM
mckeand13
Nov 21, 2006 01:33 AM
