Lowering the accord finally
Old Apr 29, 2008 | 10:09 PM
BuntinBoy9's Avatar
Default Lowering the accord finally
hey i plan i getting tein basic coilovers for my accord this summer currently the suspension is all stock but im rolling on 18" enkei or52's so here is my ? i wanna lower my car like 2" maybe more if i can so what should i put the ride hright as and what type of camber kit do i need to get and from where for how much .... preciate it
Old Apr 29, 2008 | 10:46 PM
finch13's Avatar
Default RE: Lowering the accord finally
Measure the height your car is from the fender to the ground before you install. Install the coilovers and lower them until the car is a low as you want it. Camber kits are pretty spendy, I know there are a few around.
Old May 1, 2008 | 06:54 PM
BuntinBoy9's Avatar
ok cool i have measure it now and from bout the lowest point i have 6 1/2 inch clearance soooo
Old May 1, 2008 | 08:06 PM
j_man_honda's Avatar
Easiest thing to do is just take off you stock struts/shocks/springs, measure them from top to bottom, then set your coilovers overall height 2" shorter than the factory ones. Just remember, the springs on the coilovers will settle a 1/4"-1/2" over the first 4 weeks of riding on them. Are you doing the install or what? If you have zero experience with suspension id recommend a mechanic do the job. And camber kits can be found on ebay reasonable. I got mine off there, i think the brand was springtech or something like that.
Old May 1, 2008 | 09:20 PM
BuntinBoy9's Avatar
ok ya it would be my first time doin it but i have the research done and a guy who put springs on a 91 integra to help me also sooo... is that good enough???? my dad would be halpin also and he is almost done building an airplane... handy person he is
Old May 1, 2008 | 10:22 PM
ORIGINAL: BuntinBoy9
Yeh you should be god then. I mean its pretty straightforward. Its just getting them set to the right height that is time consuming and aggravating
Old May 1, 2008 | 10:48 PM
peter4jc's Avatar
That's true. Man, I was happy when I put the car back on the ground and the height was where I wanted it. After all that, the last thing I wanted to was put it back on jack stands, take off the wheels, and adjust the coilovers again.
Like j_man said, measure the stock units, and then adjust coilovers. I like to measure the car's height at the top of the wheel arches on the fenders, just for reference.
Old May 3, 2008 | 02:52 PM
BuntinBoy9's Avatar
ok kool but should i air on the caustion side and put like 3/8 of an inch (in between the 1/4 and 1/2 inch expectance of the car settleing) so that i could guesstimate it and try to get it close to the ride hieght that i want???
Old May 3, 2008 | 08:04 PM
If you want too, why not... Im not sure of the exact amount but the springs will settle some, not much but some
Old May 3, 2008 | 10:11 PM
BuntinBoy9's Avatar
ok kool well i will air on the side of caution a little bit then how much did urs settle and what brand do u have?????
Tomtn2008
Feb 21, 2008 11:38 AM
02Hawkord
Feb 21, 2008 10:57 AM
GirlyAccord
Feb 19, 2008 10:22 AM
tunedis95
Apr 22, 2006 08:43 PM
gookie monster
Feb 22, 2006 10:59 PM
