Which lowering springs ?
Old Nov 26, 2007 | 05:20 PM
Chaqui04's Avatar
Default Which lowering springs ?
I have a set of eibach pro kit springs which is 1.2 f 1.3 rear on my 04 accord coupe which i want to lower itmore i've been looking for other springs like eibach sportline1.9 f 1.4 rear, tanabe 1.8 f 1.7 rear or skunk2 2.0 f 1.8 rear i really don't want to go with coilovers can someone help and tell me which is the best pick out of this three .
[IMG]local://upfiles/8971/C1FB39FBC6654D8CB1FC211AC6689AAC.jpg[/IMG]
Old Nov 26, 2007 | 05:24 PM
sir_nasty's Avatar
Default RE: Which lowering springs ?
tough call on that one.... I've heard great things about the Eibach, Skunk2 has a great name/reputation and tanabe would be the lowest on my list out of those three.
Depending on what you want to accomplish with the springs (aside from lowering/asthetics) I'm a BIG fan of H&R, they do take some ride quality away but deliver amazing performance.
http://hrsprings.com/scripts/appguide.php?Mode=Application+Guide&SubMode=Fi nd2&Year=2004&ModelID=201&q=2004%20|%2 0Honda%20|%20Accord
Old Nov 26, 2007 | 05:25 PM
klrspz's Avatar
Damn, wanna lower it more!?!?
My pro-kit brought it down as low as I am comfortable doing... Although, I also put my Koni's on the lowest clip setting possible as well...
good luck to ya!
Old Nov 26, 2007 | 05:31 PM
sir_nasty's Avatar
so which one would you go with klrspz?
Old Nov 26, 2007 | 05:36 PM
Chaqui04's Avatar
Well what i'm trying is tocover the most possible gap between the tire and the fender with out changing to coilovers.
[IMG]local://upfiles/8971/49BC7CA67FD2404CA82C49373D6CE622.jpg[/IMG]
[IMG]local://upfiles/8971/FE14224A75E640EFAADA3934F3A4666A.jpg[/IMG]
[IMG]local://upfiles/8971/E33D1D684D234F00AB89FE1017E491AC.jpg[/IMG]
Old Nov 26, 2007 | 05:46 PM
klrspz's Avatar
Get bigger rims?
Also, you might wanna check your numbers again...
The Eibach Pro Kit is: 1.4" front, 1.2" rear
When settled, people say they really rest another 0.1-0.15" more.
The sport line will lower it almost another half inch easily in the front, but in the end it's your call.
I dunno.. I'd be afraid of rubbing tire any lower than that personally, but I don't know much bout that. Suppose worst case scenario you roll the fenders?
Old Nov 26, 2007 | 06:15 PM
Chaqui04's Avatar
Honda 03-05 Accord (2/4Dr, 3.0L V6, Exc. Hybrid) Eibach Pro-Kit Springs (4044-140)L V6, E[*]Avg Lower for Pro-Kit F(1.2"), R(1.3") xc. Hybrid) Eibach Pro-Kit SpringsEIBACH-PROKIT-4044-140-002. This is what i got now.
Old Nov 27, 2007 | 09:58 AM
falkore24's Avatar
Of the 3 listed, I'd go with the Eibach's ...... Skunk2's are just as good, but are much stiffer. Personally, I'd use progress for a progressive spring rate spring.
Old Nov 27, 2007 | 11:31 PM
ckebottle's Avatar
How hard was the install for the springs and shocks?
Old Nov 28, 2007 | 02:02 PM
Chaqui04's Avatar
It was easy the only thing i had to do was take the parts to a friends shop to use the tool to compress the springs.
