is it necessary to get new strut towers with coil-overs?
Old Oct 30, 2006 | 08:00 PM
thunder_x's Avatar
Default is it necessary to get new strut towers with coil-overs?
i read that from this forum i found on yahoo
http://www.mustangevolution.com/foru...ings-6910.html
"the only thing about coil overs is that they are known to put a lot of stress on the strut towers, and most manufacturers recomend using camber/caster plates with the coilovers to help distribute the stress on the strut towers"
has anyone had any expereince?
Old Oct 30, 2006 | 08:03 PM
sir_nasty's Avatar
Default RE: is it necessary to get new strut towers with coil-overs?
I know that using coilovers and lowering a car puts excessive stress on your struts/shocks since they are in a compressed situation all the time and will make them blow faster but I haven't heard about their being a problem with added stress on the tower itself requiring a camber plate for help.... you need camber plates to adjust camber but that won't alleviate the stress on the struts.... it may distribute it more evenly on the tower though....
Old Oct 30, 2006 | 09:25 PM
YeuEmMaiMai's Avatar
your strut towers are actually part of the unit body of the car and cannot be replaced short of welding in new ones after cutting out the old ones.
What they are referring to is the strut bearing plate that has a large bushing in it as indicated by #13,10, and 9 below
When you lower a car you need to install a camber/caster kit if you want everything to get alligned properly....
Old Oct 30, 2006 | 09:28 PM
thunder_x's Avatar
camber plate is the same thing as camber kit?
zeus159
Jul 3, 2015 01:03 AM
jhungalmunkee
May 8, 2012 03:15 PM
thunder_x
Apr 26, 2006 02:11 PM
19accord95
Feb 11, 2006 02:06 AM
