Shaft vibration
Old Jan 23, 2008 | 06:42 PM
alegzmex
Default Shaft vibration
Hi all
Accord 05 Automatic transm 5 speed, 4cil 4dr 2.4 l
Car was vibrating very much to the sides when accelerating aprox at 50-60 mph, or any medium -hard acceleration,
after acceleration, or at steady speed car stops vibrating and rides perfect.
Ilubricated joints and imporovedd a little bit, and finanly changed rigth (passenger side )shaft asssmbly.
problem reduced 80% , still vibratesto the sides when accelerating, much much less than before,
I will lubricate left joint , before replacing left shaft assembly, is there a chance
1- I need to change driver sideshaftasssembly also
2- Vibaration colud come from some where elseand wont be reduced more.
NOTE THAT CAR HAD AN ACCIDENT IN THE FRONT PASSENGER SIDE, was parkedfor 6 monthsand fixed. thats the reason both shafts could be not straigth.
Thanks for your comments
sorry for the explanation, it is not very technical
RGDS
ALEX
Mc allen TX
Old Jan 23, 2008 | 06:54 PM
alegzmex
Default RE: Shaft vibration
FYI forgot to post
TIRES ARE NEW, ALIGNED AND BALANCED
Thanks
ALEX
Old Jan 24, 2008 | 11:17 AM
00AccordLX5spd's Avatar
Registered User
I hate to tell you, but the accident could have caused some damage that will neverallow the car to be "normal" again.
Old Jan 24, 2008 | 12:29 PM
finch13's Avatar
^x2. Control arms, linkages, tie rods, ball joints, etc. could all be bent and then even if you replaced those, where they mount to the chassis could be screwed up as well.
Old Jan 24, 2008 | 12:30 PM
sir_nasty's Avatar
your brakes dragging a bit or warped rotors as well as bad motor mounts could possibly cause those issues as well.... is anything bent or damaged currently?
Afnan
Nov 19, 2013 05:52 PM
Bilster
Nov 19, 2011 09:17 AM
golpha
Nov 25, 2006 12:06 AM
accord4sroy
Apr 22, 2006 02:40 PM
amyandrew2
Apr 15, 2006 03:40 PM
