Spindle Nut size wrong in book
Old Mar 7, 2012 | 07:13 PM
brandon0409's Avatar
Default Spindle Nut size wrong in book
I have a 1995 Honda Accord.
I was recently looking at the book on my car's parts measurements and it says multiple times that the Spindle Nut is 24mm x 1.5mm.
But when I measured it with a ruler, it was 38mm. Why the discrepancy?
Old Mar 7, 2012 | 07:42 PM
crispin's Avatar
You measured the outside of the nut
The numbers in the book are for the thread size -- ie the inside open area of the nut.
12mm is the width, 1.5 is the thread pitch
Old Mar 7, 2012 | 08:21 PM
Oh. Why would they give the inner dimensions of the part in a how-to guide to disassemble the wheel assembly?
Interesting.
Thanks for the reply though.
Old Mar 7, 2012 | 09:44 PM
crispin's Avatar
Interesting.
Because if you need to purchase a replacement nut you would need to know what size and thread pitch it is.
The outside diameter can vary.
Old Mar 8, 2012 | 01:53 AM
No. Actually I was trying to buy the socket so that i could remove the nut. Funny thing. When I went to the store to get the socket I kept asking for 24mm. But it was clearly too small. I sat there and looked hard at the 24mm socket I was holding and I knew that that was to small. but then I began second guessing. But I figured I'd go and stick a ruler against is and measure it.
No big deal. I'll just but the socket tomorrow.
Old Mar 8, 2012 | 06:51 AM
crispin's Avatar
on my 97 I needed a 36 mm socket to take that nut off
Old Mar 9, 2012 | 06:22 AM
Apparently, when I measured it with this triangle ruler, every side had a different measurement. I was positive that they were mm but apparently were not. I feel kind of stupid. But I found a standard MM ruler and discovered that it was indeed 36mm.
JonJon13926
Jul 13, 2013 11:51 AM
RobinsonRicer
May 12, 2013 04:51 PM
RobinsonRicer
May 9, 2013 01:26 PM
drummer1279
May 29, 2008 08:56 AM
Hop
May 18, 2007 12:47 AM
