Steering wheel shakes...
Old Jul 23, 2007 | 08:27 PM
Boostedv6's Avatar
Default RE: Steering wheel shakes...
If you have already done the bearings, cv joints and such...
All you need is a wheel alignment, front and back...and check your tires as well.
Same thing happened to me...
Old Jul 24, 2007 | 01:03 PM
finch13's Avatar
Just had a full alignment 2 weeks ago. Can't exactly switch the front tires as I have directional racing tires (came with the wheels, not my choice). I can't visually see if anything is bent but my mechanic noticed I bent the control arm the first time and checked it when I returned for the alignment. Just thought of this now: I has to be within the steering system because the car still pulls when I use my higher treadwear tires for roadtrips...
I have more serious suspension issues to deal with before I go to college in a few weeks... thanks for all the help.
Old Jul 24, 2007 | 01:10 PM
smaglik's Avatar
were the tires balanced recently? a bad tire will be nearly impossible to balance.
Old Jul 25, 2007 | 12:47 PM
finch13's Avatar
Yes, all 12 of the tires have been balanced. Still pulls the same amount, same side, with any of my tires on it.
Old Jul 25, 2007 | 02:57 PM
Carbon91EuroR's Avatar
you my also want to check your radius rod on the side you hit, you may have moved it from it's seating or loosened up the lock nut, letting the the bushing give.
Old Jul 25, 2007 | 10:45 PM
smaglik's Avatar
cool avatar carbon91
  #17
smaglik's Avatar
Old Aug 22, 2007 | 01:57 PM
  #18
falkore24's Avatar
A friend's SI had an issue with pulling to the left. He had it aligned and it still pulled. The problem was that the engine mounts were shot. We replaced them and the problem's gone. In your case, it sounds like you lost a wheel weight, so you should have them checked/balanced.
DaWells84
May 6, 2012 09:57 AM
remgene
Jan 5, 2012 11:50 AM
Jcaleno
Jun 4, 2009 07:05 AM
hatingmyhonda
Jan 25, 2008 09:39 AM
Jul 3, 2005 03:38 AM
